| Inspection Education & Training This is a general forum for inspectors to discuss their educational experience, and to ask questions of InterNACHI's Education Committee. This forum is dedicated to the memory of InterNACHI member and educator Gerry Beaumont. Gerry was an avid proponent of education for inspectors and will be sorely missed. |
December 9th and 10th at the Holiday Inn-Select, in St. Peters, MO....the NACHI Caravan pulls in from Canada to offer another great session. Both classes start at 8:00 a.m. and run to 3:30 p.m. Fees are $50 for NACHI members and $100 for non-members.
For more info, see our chapter website at www.monachi.org Day One - 12/9 is Plumbing for Home Inspectors. Here is the outline: Plumbing Course Outline - 1 Day (6 CEUs) Course Overview: Purpose Elements Application Testing Evaluation Note: As a pre-requisite, the inspector should have clear understanding of their association’s Standard’s of Practice and Code of Ethics and/or their State/Provincial inspection guidelines, where applicable. Plumbing Introduction: Definition of Plumbing Components of Plumbing – Water Supply, Drain, Waste, Venting, Fixtures, Appliances, etc. Standards of Practice - Refer to Industry Associations Code of Ethics - Refer to Industry Associations Inspection Tools & Application Inspection Techniques, Safety, Reporting Methods & Qualifying the Client Types of Plumbing: Materials Used in Plumbing – Copper, Lead, Galvanized, ABS, PVC, Pex, Poly-B, Combination, etc. Pros & Cons of Each Type Styles of Plumbing: Designs – City (Municipal) vs. Rural (Private) Application - Soldered Joints vs. Compression or Crimped Pros & Cons of Each Style Combining Styles - Common Combinations - Considerations Plumbing Systems: Water Supply – Curb Stop, Main Shut-off, Water Meter, Distribution Pipes Drainage – Main Clean-outs, Stack, Traps Venting – Dry vs. Wet Cisterns, Wells & Septic Systems Mechanicals – Hot Water Tank, Expansion Tank, Pumps, Humidifier, Appliances Valves, Fixtures, Faucets, etc. Plumbing Pluses: Frost-free, Anti-siphon devices, Isolation Valves, Steel-braided Hoses, Insulation, etc. Plumbing Deficiencies: Defect Recognition - Recognizing Problematic Areas, Workmanship Quality, Weather, etc. Reporting Concerns & Issues for the Inspector Question period / Open forum Evaluation: Course Evaluation form handed out for completion & return (includes comments & suggestions) Day Two - December 10 is Framing for Home Inspectors. Here is the outline: Framing Course Outline - 1 Day (6 CEUs) Course Overview: Purpose Elements Application Testing Evaluation Note: As a pre-requisite, the inspector should have clear understanding of their association’s Standard’s of Practice and Code of Ethics and/or their State/Provincial inspection guidelines, where applicable. Framing Introduction: Definition of Framing Components of the Framework – Structural Supports, Floors, Walls, Ceilings, Roofs, etc. Standards of Practice - Refer to Industry Associations Code of Ethics - Refer to Industry Associations Inspection Tools & Application Inspection Techniques, Safety, Reporting Methods & Qualifying the Client Types of Framing: Materials Used in Framing - Wood, Metal, Combination Pros & Cons of Each Type Styles of Framing: Designs of Construction – Stick Built & Balloon Pros & Cons of Each Style Combining Styles - Common Combinations - Considerations Framing from the Ground & Up: Support Beams & Posts, Sill Plate, Rim/Band Joist, Floor Joists, Blocking, Sub-floor Wall & Nailer Studs, Cripple & King Jacks, Headers/Lintels, Upper & Top Plates, Wall Sheeting Ceiling Joists, Rafters, Trusses, Roof Sheeting Framing & Next Steps: Insulation, Vapour Barrier, Framing Deficiencies: Defect Recognition - Recognizing Problematic Areas, Workmanship Quality, Weather, etc. Reporting Concerns & Issues for the Inspector Question period / Open forum Evaluation: Course Evaluation form handed out for completion & return (includes comments & suggestions) James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 225 | 10/18/11 7:54 PM |
| How To Stop Your Home Inspection Clients From Suing You! | rray | General Inspection Discussion | 17 | 6/4/08 3:22 PM |
| "Law & Disorder" Seminar Coming to New Hampshire | fcarrio | Legislation, Licensing & Legal Issues for Inspectors | 0 | 7/3/07 4:39 PM |
| 2-Day Training Seminar - St. Louis, MO | jbushart | Miscellaneous Discussion for Inspectors | 4 | 12/7/06 10:23 AM |
