Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Education & Training
Inspection Education & Training This is a general forum for inspectors to discuss their educational experience, and to ask questions of InterNACHI's Education Committee. This forum is dedicated to the memory of InterNACHI member and educator Gerry Beaumont. Gerry was an avid proponent of education for inspectors and will be sorely missed.
Old 5/10/11, 4:54 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Wood-Destroying Organism Inspection Course
This thread is dedicated exclusively for those students currently enrolled in the InterNACHI course titled, "Wood-Destroying Organism Inspection Course" located at http://www.nachi.org/wdocourse.htm
Thank you.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/12, 8:25 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Default Re: Wood-Destroying Organism Inspection Course
This is from Chapter 17: Foundation Structures
Figure 108. A structure with a floating slab and hollow concrete block foundation wall with arrows indicating potential termite entry points
This is a picture of a supported slab repeated from Figure 106.
Thanks!
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 2/19/12, 8:30 PM
Found another error in Chapter 20: Basic Construction Terminology
fascia: horizontal boards attached to rafter/truss ends at the roof eaves and along gables. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
Should be the vertical boards, or the gutters won't catch the runoff very well!
Thanks
Chad Norlen
SEI Inspections
Old 2/19/12, 8:41 PM
Nick Gromicko's Avatar
The vertical update has been made. Waiting for researchers to decide about floating slab PIC.
Find a Home Inspector
Old 2/20/12, 11:29 AM
Thanks
Here's InterNACHI's definition of "fascia," which is a term used in architecture to refer to a frieze or band running horizontally and situated vertically under the roof edge or which forms the outer surface of a cornice and is visible to an outside observer. This is to say that the long dimension of the surface is horizontal and the short dimension is vertical. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
http://www.nachi.org/glossary/f.htm
click this small screen shot above
BEN GROMICKO
Old 2/20/12, 11:31 AM
The "fascia" definition within the course has been returned to its original, with an update of the definition.
fascia: a term used in architecture to refer to a frieze or band running horizontally and situated vertically under the roof edge or which forms the outer surface of a cornice and is visible to an outside observer. This is to say that the long dimension of the surface is horizontal and the short dimension is vertical. Gutters are typically attached to the fascia. Fascia boards are commonly attacked by carpenter bees.
BEN GROMICKO
Old 2/20/12, 11:42 AM
Thanks!
Chad,
Good catch. Thank you.
That was indeed simply a repeated illustration from a few paragraphs prior. A new illustration has been inserted (below).
Figure 108. A structure with a floating slab and hollow concrete block foundation wall with arrows indicating potential termite entry points (illustration courtesy of MSUE)
BEN GROMICKO
Old 2/20/12, 11:59 AM
Thanks Ben, thanks Chad!
Old 2/21/12, 11:13 AM
Termite tube on sill plate
When looking for signs of termite activity, the inspector must be alert to those conditions that favor termite infestation. The most critical condition is wood-to-soil contact.
BEN GROMICKO
Old 3/20/12, 5:58 AM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is online now
Thanks Ben.
Maybe IAC2 should have a similar thread.
JMO.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
InterNACHI's free, online Wood Destroying Organism Inspection course updated. gromicko Inspection Education & Training 0 3/5/09 12:38 AM
Mold Resistant Wood by FrameGuard mcyr General Inspection Discussion 15 1/16/09 9:14 AM
Free, comprehensive, online, Wood Destroying Organism Inspection Course. gromicko Inspection Education & Training 0 9/15/08 1:01 PM
The Rise and Fall of CCA Wood Preservatives mcyr General Inspection Discussion 3 5/4/08 11:19 AM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 8:30 AM
