| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: A brick veneer wall built with 4" standard brick has a fire rating of? | |||
| 3-hr rating. |
2 | 8.33% |
| 2-hr rating. |
5 | 20.83% |
| 1-hr rating. |
7 | 29.17% |
| None of the above. |
10 | 41.67% |
| Voters: 24. You may not vote on this poll | |||
jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Under standard building conditions a Brick Veneer Wall using 4" standard brick is rated?
John you are good at these polls.
I would like to add this below to help the members or some anyways. Constructing brick veneer over existing walls of combustible materials will decrease the possibility of externally initiated fires. Typical brick veneer wall assemblies have fire resistance ratings. Brick veneer wall assemblies can attain fire ratings. The combustible wood stud must be protected from fire on each side by noncombustible materials that meet the required fire rating. A 4 in. (100 mm) nominal brick wythe provides a fire rating. Brick masonry has superior fire resistance. Building codes may require that exterior walls have a fire resistance rating based on fire separation distance, size of building and occupancy classifications. They may require protection from one or both sides, depending on whether the fire separation distance is more or less than 5 ft. respectively. A nominal 4” brick Wythe has a fire resistance period of ______ minutes resulting in a __ hour fire resistance rating and can provide this protection for the exterior surface of the wall. Hope this helps some. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
This is just for understanding of fire ratings and endurance.
http://www.awc.org/Publications/dca/dca4/DCA4.pdf Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I'm surprised to see such varied answers....
If you all look in Chapter 7 of 2003 IBC there is a prescriptive method for calculating fire resistance of a wall assembly. |
Thought I would add this in to help.
One-hour wood construction is the most common of the rated construction built today. Yet many of the construction techniques and detailing are not commonly understood or practiced. Rated construction is a system of building components which protect a building from fire. A whole building can be of rated construction or just one element of a building. It is essential that the rated construction act as a whole. Integrity of the construction around openings and through wall and floor cavities is essential regardless of the purpose of the rated construction. Purposes of one-hour construction:
Be careful, just because a material may be very difficult to burn, does not mean it has a fire rating.
Typically the fire rating is of the entire wall system, brick/exterior sheathing/studs/insulation/interior sheathing/ glass etc. The material used for the opens, windows/doors also have to be taken into consideration. |
C. was the correct answer.
A 4" brick veneer wall has a 1-hour fire rating. If the interior walls are properly covered the total wall fire rating is increased to 2-hour. |
| Brick Veneer Walls - Weep Holes | jbowman | Inspection Question of the Day | 20 | 4/28/08 2:09 PM |
| Brick Veneer Walls - Height | jbowman | Inspection Question of the Day | 6 | 12/16/07 8:37 PM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 7:34 PM |
