Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Question of the Day
Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: See Post #1 for question and answer below.
Minimum of 1/4-inch up to a maximum of 3-inches in length. 7 17.95%
3/8" dia. (hole) up to the length of 1 mortar joint between 2 bricks of a course (3 ½ inches). 16 41.03%
5/8 wide up to 6-inches in length. 0 0%
No standard min. & max. weep hole opening sizes have been established by any code or standard. 16 41.03%
Voters: 39. You may not vote on this poll
Old 11/30/07, 3:33 PM
John Bowman's Avatar
John Bowman John Bowman is offline
Please Note: jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Brick Veneer Walls - Weep Holes
What is the minimum and maximum opening allowed for weep holes in Brick Veneer Walls?
A. Minimum of 1/4-inch up to a maximum of 3-inches in length.
B. 3/8 inch diameter (for round holes) up to the length of one mortar joint in between two adjoining bricks of a course (normally 3 ½ inches).
C. 5/8 wide up to 6-inches in length.
D. No standard minimum and maximum weep hole opening sizes have been established by any code or standard.
Old 11/30/07, 3:58 PM
Roy D. Cooke, Sr's Avatar
Default Re: Brick Veneer Walls - Weep Holes
Great way to start you third thousand posts thanks John b.
...Cookie
Old 11/30/07, 6:26 PM
John you sly fox, were you a mason in your past life? ha. ha.
I can't choose correctly with what you posted. I'll explain when you give the answer.
Marcel
Old 11/30/07, 8:44 PM
Marcel,
Great. I'm always willing to learn. At this point and time I only see one correct answer, but a man with your experience will surely enlighten me.
Can't wait and am looking forward to the additional information that you have.
Old 11/30/07, 9:27 PM
Barry Adair's Avatar
Mums the word, right Marcel
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/30/07, 10:01 PM
Remember...This question is relevant to Brick Veneer Walls and not solid load bearing brick walls.
Old 12/1/07, 7:30 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am with Marcel on this one
Old 12/3/07, 9:57 AM
I'm with Marcel and Charles on this. Please disregard this question because it is in error and I have been corrected.
There is a minimum size requirement for weep holes. The 2000, 2003, and 2006 IRC all stipulate:
R703.7.6 Weep holes.
Weep holes shall be provided in the outside wythe of masonry walls at a maximum spacing of 33 inches (838 mm) on center. Weep holes shall not be less than 3 /16 inch (4.8 mm) in diameter. Weep holes shall be located immediately above the flashing.
Thank-you Marcel and Charles for forcing me to investigate further.
Old 12/3/07, 10:39 AM
Your welcome John and I did not want to spoil the game prematurely, because this is how we all learrn.
Thanks
Marcel
Old 12/3/07, 11:53 PM
Joseph Hagarty,  CMI's Avatar
John,
Just add "None of the Above" to the Poll....
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 12/4/07, 12:06 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
here is a link to a blog I did .
For anyone looking for a basic on brick veener.
Sorry about the lousy diagram as it was my first.
http://activerain.com/blogsview/2042...ick-veneer-the
Old 12/4/07, 12:40 AM
cbuell's Avatar
John, it is pretty rare day that I don't learn something and I am pretty stubborn
Old 12/4/07, 8:38 PM
I think that John's minumum might not be small enough. ha. ha.
http://www.tamlyn.com/documents/WeepHmouse.htm
Marcel
Old 12/4/07, 8:47 PM
relliott's Avatar
Ha Ha ...Good one Marcel.
Old 12/4/07, 9:46 PM
Hi. Bob;
Here is the other half. ha. ha.
http://www.tamlyn.com/documents/weephcomerical.htm
I thought that was a pretty good commercial on the product.
Marcel
New Construction & No Weep Holes jfunderburk Exterior Inspections 38 5/26/11 12:28 PM
Backfill on brick veneer bpaull Exterior Inspections 4 7/12/07 8:40 AM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
Massachusetts Clay Brick Education ajalowsky Miscellaneous Discussion for Inspectors 2 2/22/06 7:34 PM
