Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Question of the Day
Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: See Post #1 for question and answer below.
20 minute 2 5.71%
30 minute 0 0%
60 minute 6 17.14%
120 minute 18 51.43%
90 minute 9 25.71%
Voters: 35. You may not vote on this poll
Old 11/2/07, 8:31 AM
John Bowman's Avatar
John Bowman John Bowman is offline
Please Note: jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Commercial Inspection - Doors 2
Question:
Doors located in 2HR rated occupancy separation walls shall have the following rating...
Choices:
20 mins
30 mins
60 mins
120 mins
90 mins
Old 11/2/07, 4:13 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: Commercial Inspection - Doors 2
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 11/2/07, 7:37 PM
John, that is a good one. It is obvious to me that you have picked a good poll.
Thanks
Marcel
Old 11/3/07, 10:58 AM
Barry Adair's Avatar
The answer is contained within this doc
http://www.steeldoor.org/res/118.pdf
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/3/07, 11:42 AM
Barry;
I think you have just closed the Poll.
I know I am one of the four on the 90 min. and was hoping to see how many were going to vote for the 120.
Oh well.
Marcel
Old 11/5/07, 8:30 AM
Originally Posted by mcyr
Barry;
Oh well.
Marcel
My poll says badair waits 72 hours before posting how about yours
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/5/07, 11:17 AM
Mike Hazelwood's Avatar
Mike Hazelwood Mike Hazelwood is offline
Just a curious question....Why is the door only required to be 1.5 hour rated and the walls are 2 hour rated? A chain is as strong as its weakest link.
Old 11/5/07, 1:14 PM
This might help a little.
It is common for a fire door to have a fire protection rating lower than the wall fire resistance rating in which it is installed. This is justified in part by the fact that, under normal conditions of use, the potential fire exposure in the vicinity of a door opening is decreased, since there will usually be a clear space on both sides of the opening for traffic purposes. Since wall assemblies are put together at the site, their uniformity is not as certain as a fire door assembly that is factory assembled (e.g., undesigned penetrations tend to show up in wall assemblies). For this reason, any factor of safety that is tacitly called for in a wall assembly requirement should exceed that of a door assembly. If the opening is not used, combustibles could be piled against the door, and the assumed enclosure protection might not be maintained. I these instances, ratings for the openings should be equivalent to the rating of the wall, or precautions should be taken to prevent storage of combustibles against the doors.
Ref. NFPA 252 Standard Methods of Fire Tests of Door Assemblies
Marcel
Commercial Real Estate Doing Better than Housing jbushart Miscellaneous Discussion for Inspectors 3 10/23/07 10:34 AM
Commercial Building & Thermal Imaging Course Coming to New Hampshire fcarrio Commercial Inspections 1 8/13/07 1:47 AM
Article on Commercial and Residential Inspections and Assessment mcyr Commercial Inspections 2 8/6/07 2:26 AM
