| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: See Post #1 for question and answer below. | |||
| 44-inches. |
4 | 18.18% |
| 24-inches |
1 | 4.55% |
| 30-inches |
3 | 13.64% |
| 42-inches |
5 | 22.73% |
| 36-inches |
9 | 40.91% |
| Voters: 22. You may not vote on this poll | |||
jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
When installed panic hardware shall be mounted at a height not less than ____ inches?
a. 44 inches |
John
I have to go with 42" Our building code only specifies NOT higher than 47" and I guess they forgot to talk about min height. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Good trick question John.
Code minimum allowed and standard mounting heights are two different answers that are not easily interchangeable for Commercial hardware. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Under normal construction techniques those that selected 36" would be correct. However special considerations are made for Day Care centers and facilities that provide services or housing to shorter individuals. In these facilities a minimum may be as low as 24-inches.
Just thought I would add this in to not cause any confusion.
Although fact that a minimum mounting height for panic devices may be 36", Most all Commercial Hardware is installed at 41" to the center of the push bars. Where a vertical rod device may be used, the centerline height would be at 39 & 13/16 off of finish floor. Any other height would cause the top rod or bottom rod to be short or too long. Residential and light Commercial usually have hardware preparations on the frames and doors set up for 36" centers. Full commercial hardware, doors and frames are always preped for 41" center hardware mounting. Commercial hardware will not mix with Residential doors and frames unless custome ordered. Everything from templateing and mounting are usually different. TH1100EDTBAR - TOUCH BAR Global Series TH1100EDTBAR touch bar style exit devices are suitable for all doors (aluminum, hollow metal, or wood) where there is no projection on the face. Manufactured of extruded anodized aluminum, the TH1100EDTBAR is durable enough for the most demanding applications. A rim cylinder is included, and the EDTBAR can also be used in conjunction with any of the exit device trims listed below. Specifications
Higher the better, not exceeding the recommended code in your area.
44" on center of the bar. Steve Blayney Certified Home Inspector Certified Energy Advisor NACHI Property Systems Inspection 416 886-2PSI (774) sblayney@p-S-i.ca www.Nachi.org Remember, no home is perfect! |
24"is also recommended for people confined to Wheelchairs.
I've been looking for this information. If you don't mind would you share your reference? |
![]() Mounting Heights Allowable mounting heights for exit devices are the same in each model code: not less than 30" nor more than 44" above the floor. While design may dictate where the push bar is located, consideration should be given in assigning a mounting height to either the lower or upper limits. The lower height is suggested for grade schools, while the upper height may be better suited for adult use, i.e. colleges. Consider where the trim is located on the opposite side of the door, as some manufacturers may have as much as 8"-10" differences between the centerline of the push bar and the centerline of pull trim. This height difference varies, depending on locking functions and type of exit device. Also consider applicable regulations for the physically disabled, as height requirements may vary. ADA (Americans with Disabilities Act) regulations permit 48" maximum height for accessible door hardware, while some state codes have a 42" limit. Some states also require the ends of lever trim to return to within 1/2" of the door face. NFPA 101 34"-48" NFPA 5000 same IBC same BOCA SBC, UBC 30"-44" Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That's a very good point regarding wheelchair accessiblity! Achieving the best of two worlds is the real challenge. The current bar design does not favor those in the chair, unless the door opens automatically for them. You could almost throw the codes out the window and inspect using our practical and common senses.
I would still stand behind my initial answer of 44" but include an automatic push button between 30"-36" from the ground as a secondary opener for those in wheel chairs. Steve Blayney Certified Home Inspector Certified Energy Advisor NACHI Property Systems Inspection 416 886-2PSI (774) sblayney@p-S-i.ca www.Nachi.org Remember, no home is perfect! |
Bo Murray is a non-member guest and is in no way affiliated with InterNACHI or its members.
The best panic exit bars are those made of stainless steel and contain no plastic or other weaker materials. The comments before already answered the height issue correctly, so I will not write it again. I hope the information I provided helps you in your choice.
| Holiday cookie recipes - Enjoy! | jonofrey | Miscellaneous Discussion for Inspectors | 11 | 11/7/07 9:42 AM |
| Commercial Real Estate Doing Better than Housing | jbushart | Miscellaneous Discussion for Inspectors | 3 | 10/23/07 10:34 AM |
| Commercial Building & Thermal Imaging Course Coming to New Hampshire | fcarrio | Commercial Inspections | 1 | 8/13/07 1:47 AM |
