| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: Are ducts allowed through fire resistant walls? | |||
| No |
6 | 30.00% |
| Yes if they open into the garage |
1 | 5.00% |
| Yes if they are min 20 gage steel |
2 | 10.00% |
| yes if the are min 26 gage steel |
11 | 55.00% |
| Voters: 20. You may not vote on this poll | |||
Duct through Fire Resistive Wall Allowances
Does this duct have dampers on both sides of the wall in question?
deleted
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 10/4/08 at 9:42 AM.. Reason: gave answer I guess |
This is a bit of a tricky question as the answer is to be found under IRC Section R309.1.1, Garage Seperation.
It may seem that you would find it under Dwelling Unit Seperation Section R316. Reading further you will find in section R317 that the Townhomes and other such dwellings are to be considered seperate buildings and they are to contain no plumbing or mechanical ducts or vents. This would preclude a duct passing through such wall. Now in a commercial application depending upon the building use classification, fire and or smoke dampers would be required. The sophistication of which would be dependent upon the use and size of the building. Last edited by brickey; 10/4/08 at 8:04 PM.. Reason: typos |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wow no ducts or plumbing in townhomes, who knew? |
Outhouses are back in style!
Where cross-ventilation was a must without wall penatrations.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
2 comments -
first this is more of a code question second - the response will be different for the Canadians - eh! otherwise - good question Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
26 gauge steel is the answer I was looking for. As for smoke dampers David please enlighten me. |
deleted
deleted
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
