| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: Is this forced air gas furnace flue properly installed? | |||
| Yes |
4 | 17.39% |
| No |
19 | 82.61% |
| Voters: 23. You may not vote on this poll | |||
Courtesey of Barry Adair
Is this forced air gas furnace flue properly installed? YES NO Please provide code or other references to back-up your answer. Last edited by bkelly2; 6/12/09 at 6:48 PM.. |
Anyone can see it's too close to the turbine vent.
I don't do code. It's crooked and rusty. John Kogel www.allsafehome.ca |
This is like a joke question..?
Hmmm, actually if that is a roof vent.............. going out.......... Then it may very well be OK..
I say it is OK, but the gas vent should be taller.
Tallen ,you are correct, as it needs to be 24 inches higher than anything within 10 feet if it is B vent.
Source is Carson Dunlop and Inspect NY. |
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
The "B" vent stack is too close to it. Bad combination in any case. Call it out as further assessment required. Let the trades people figure it out. I do NOT do code (reference), just common sense. T.Neyedli www.alphahomeinspections.ca |
did You check out the lines on those shingles ????why does Barry keep posting pictures of the work he did on His own house ????
The top of the chimney must be 2' higher than anything within 10' of it.
Potential back draft problem. |
So far there are 3 votes that this is ok, yet not one explanation for why.
Lets hear it. |
The turbine is not combustible. The turbine discharges air from the attic space. The unavailable furnace mfgs. installation instructions rule. Now let's hear why most think it is an improper install. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Show us Manufacturer that says I am wrong Mike. |
What is the potential hazard? It may well be wrong but without a known hazard and lacking the installation docs, why? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
You are answering a question with a question. Your installation guides are all over the internet. Argue with, them. Find one that is different from what I referenced. Why does a brick veneer wall need a one inch space rather than a 3/4 inch space? I do not know that either. Ever hear of the 3-2-10 rule.? Me too, but I just write it up. Gee ,am I being hard on this. Seriously I would imagine there is something called back drafting , which may come into play. |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Furnace flue | abolt | Inspecting HVAC Systems | 3 | 9/7/08 3:36 PM |
| Furnace Flue | Skip Erwin | Inspecting HVAC Systems | 10 | 3/8/08 10:54 AM |
| Oil Furnace Flue Clearance | jfunderburk | Inspecting HVAC Systems | 3 | 2/28/06 7:17 PM |
