Go Back   InterNACHI Message Board > Education Topics > Question of the Day
Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: True or False?
True 23 56.10%
False 18 43.90%
Voters: 41. You may not vote on this poll
Old 1/22/07, 9:12 AM
jbowman's Avatar
jbowman jbowman is offline
Please Note: jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default QOD for 1/22/07 (Smoke Detectors)
Is the following statement true or false?
The installation and wiring requirements for smoke
detectors in Fire Alarm Systems can be found in Article 760 of the NEC.
Installation and wiring requirements for smoke alarms in residential
buildings can be found in NFPA 72. In addition to all sleeping rooms,
a smoke alarm is required outside each sleeping area (typically one is
installed in each hallway leading to sleeping rooms).
One additional smoke alarm is required on each story of the dwelling
unit, including the basement, but NFPA 72 doesn't specify exact
locations for these. Smoke alarms are not required in a crawl space or
attic.
Old 1/23/07, 5:18 PM
jking2 jking2 is offline
Default Re: QOD for 1/22/07 (Smoke Detectors)
It is false for at least the reason that there is no additional smoke detector required on the sleeping floors besides the ones in and adjacent to the sleeping areas.
Old 1/23/07, 5:27 PM
jbowman's Avatar
Answer: True
Old 4/4/07, 12:00 PM
afugett afugett is offline
Very true
Old 4/9/07, 12:40 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Okay...
I'll play Devil's Advocate.
What of requirements for existing structures, say originally built in 1980?
Old 4/9/07, 8:05 AM
jbowman's Avatar
Originally Posted by jfarsetta
Okay...
Joe,
I'll attempt to make this as short as possible.
Smoke alarm laws have been part of the building code for more than 20 years, yet are among the most frequently violated of home safety requirements. A significant number of homes either have no smoke alarms, have too few, have ones that are incorrectly placed, or which are simply inoperative. So let's take a quick look at the proper deployment of these imperative life-saving devices.
Smoke alarm requirements are not the same for every home. They vary according to local municipal standards and by the age of the dwelling. For homes built prior to 1979, battery-powered smoke alarms are permissible. In newer dwellings, (which NFPA 72 covers) alarms must be powered by the electrical wiring. The problem with battery units is that people often neglect battery replacement. On the other hand, what good are wired-in smoke alarms if you have an electrical fire accompanied by a power outage? The safest arrangement, therefore, is to install wired-in alarms, equipped with battery back-up. This type of integrated alarm can be obtained at most hardware stores and is required for homes built as of 1993.
As to smoke alarm placement, requirements also vary according to the age of the dwelling. In older homes, most municipalities require alarms in the following locations: Within close proximity to all bedroom entrances, on each story of a multi-level home, and in basements. The latest standards, enacted in 1993, require that there be an additional alarm in each bedroom. Another practical location, although not required, is the garage.
Additionally, wherever smoke alarms are installed, ceilings are the best specific locations, primarily because smoke rises. However, it is permissible to install an alarm on a wall, as long as it is within 12 inches of the ceiling.
One final requirement involves homes that are remodeled or enlarged: When the cost of an addition or alteration exceeds $1000, and whenever a permit is required, smoke alarms must be installed in compliance with the latest standards, regardless of the age of the building.
For further details regarding specific smoke alarm requirements in your area, it is advised that you consult your local fire department or code department.
Unfortunately, I do not have the regulation requirments for NYS on the selling of a home. But I do believe that the home must be properly equipped when put up for sale. Some states require certification. New Jersey for example: http://www.longhillnj.org/departments/dpw/sumppump.html
http://hisearch.org has over 1,000 hits per month and climbing. Currently ranked #1 in many search engines for determing the age of HVAC equipment. Check it out at http://hisearch.org/hvac.aspx Feel free to bookmark and use our site at any time.
List your business in our Home Inspector Registry with a link exchange. Check out your state now at http://hisearch.org/homeinspectorregistry.aspx Are you listed???
Old 4/13/07, 4:26 PM
Robert J. OConnor's Avatar
Originally Posted by jbowman
Unfortunately, I do not have the regulation requirements for NYS on the selling of a home. But I do believe that the home must be properly equipped when put up for sale.
Attached is a NYSDOS Bulletin on the smoke alarm requirements for existing residential buildings in New York.
If no permits were recently pulled for additions, or alterations requiring removal of finishes, then it appears the requirement is one smoke alarm in each unit or house on/near the ceiling certified by the seller upon transfer (see table at end of Bulletin, and FCNYS 907.3.2.1.3). Pretty minimal.
JMO ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/rjo
Old 4/13/07, 8:55 PM
jbowman's Avatar
Thanks Robert.
Old 4/14/07, 9:20 AM
This is my point, exactly.
We are not code compliance officials. We should be familiar with the laws of our area, and we know that smoke alarms are important. Here in NY, every realtor knows the law as it pertains to what requirements exist for smoke alarms and carbon monoxide detectors. This was why I asked a question that I already know the answer to. It is important to be able to parse what is required from what one might recommend.
Re-stating... essentially, in NY State, only a single smoke detector would be required in homes that existed prior to 2003, and that have had no additions or alterations to the interior which required a building permit. Battery operated units are okay.
John makes an excellent point with his reference, and the addition of more smoke detectors can never hurt. I have a simple hand out I provide my clients explaining all of this.
Good post, John
Old 4/14/07, 9:33 AM
jbowman's Avatar
Agreed...
I also made mention in my original post:
Escape, Fire & Smoke Alarms badair Interior 14 1/28/08 8:21 AM
Stand-alone Smoke detectors (posted by Pamela Bloom) AskNACHI.org AskNACHI.org Forum 1 7/10/07 3:11 AM
2 questions staylor5 Electrical 9 3/23/07 11:40 PM
Copyright © International Association of Certified Home Inspectors, Inc. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
