| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: What would you do if this happened to you? | |||
| a. Pull the dead front and find the problem. |
3 | 10.00% |
| b. Call Gerry for advice on his NACHI phone. |
4 | 13.33% |
| c. Report that dead front not removed and defer to an electrician. |
23 | 76.67% |
| d. Call your helper so he can remove it. |
0 | 0% |
| Voters: 30. You may not vote on this poll | |||
Lets try some electrical questions for the rest of the week.
This is an easy one. Greg Bell Titusville, Fl 02111507 Serving Central Florida
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Grounding Issues - defer to electrician for further evaluation.
-- Andrew Rook Rook Home Inspections LLC New Jersey Home Inspector Hamilton, NJ Be Smart, Be Sure, Be Inspected TM |
I'd probably check the panel with a voltage meter simply because my non contact "pen" goes off within a few inches of a panel. If I rub it on my arm it goes off too. Must be my electric personality.
If all else fails, I'd answer "d". lol Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Defer to the Electrical Experts on the Board...I take the 5th !
NO actually I would call Gerry.......he could tell me what to do.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
The problem is that the panel is at ground and the inspector is standing on a electric blanket that is wet
This is the WRONG way to test a panel. Paul tell them how it is to be done and also give a guess of how many professional electricians test a panel before removing it rlb |
lol....again Richard I defer to the Electrical Experts...I am just an electrician from Virginia......I defer...defer...defer......
On the comment about how many electricians test before removing...I take the 5th.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
lol...actually one of my helpers ticked me off today so I would probably have HIM go remove the cover....BUT give me 5 minutes with it privatly before I allow him to mess with it........
Paul
Ok I sort gave you a slider on this one But lets look at Ohms law -- Panel face plate hot -- that means that screws are connected to the main panel that are connected to a hot box and or a hot wire and no other bolts are connected to the box which are connected to ground or neutral. In short it is hard to create a hot panel - thus very seldom is it even checked -- Sort of like checking for a gas leak in an all electric home or 120 volts on a phone line. Yes I could happen but lets get back to reality -- The time to check with the risk = to many 1,000,000 to one does not equate to something that would be even put into an SOP or a MOP Greg Bell is posting questions and situations that are good for the BB but not something that is close to the real world If checking to see if a DP should be checked to be hot as part of a MOP then so be it but I would like to see any industry published statement to say do so. If so I will change my ways And trust me I am 100% for safety Paul -- your are in both the HI and the Electrical profession what is your call ?? If Mr Bell off base then call it --- his background is not ohms law rlb Last edited by rbennett; 11/1/06 at 10:10 PM.. |
ahhh........yeah...what RLB said....lol...
Wait.....hell man...I deal in OHMS LAW all the time.....I did not see any MATH on that page...tehehhehehe HOWEVER........if the panel is IMPROPERLY BONDED and their is a high enough resistance...it is QUITE possible...... WE know that using OHMS LAW.......even a short to a ground rod that lets say for argument sake is 25 OHMS......and apply 120V to it...what is the AMPS....4.8 AMPS on an improperly grounded system will NOT remove stray voltage and could possible cause the equipment ( in this example a street pole for example ) to become energized and NEVER cause a fault situation.... yeah...it could happen...lol Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
You make some great points Richard......
If the panel itself is not bonded properly, and the system is is missing a GEC for that matter....we loose the balanced potentil argument....so...is it possible for a panel to TICK without tripping the breaker or faulting out.... Personally I think it is quite possible..... If the panel becomes energized due to lets say a sheetrock screw being used as a panel cover screw......and the panel has not been bonded correctly..... What is quite scary is that people think the ground rod actually will save them in a situation where they are getting shocked..... The surface voltage gradients are going to be progressivly less the furthur you are away from the ground rod...IF one was present.....so if one is not present.......the ground rod is useless in this anyway.....where was I...oh sorry....I digressed... Ok....earth itself is not a good effective ground fault path.....neither is a concrete floor for that matter if you are thinking hell I will just shock myself on a floor......other than earth... Point is........it is quite possible for a panel that is improperly bonded....and if in the main means no connection between the grounded conductors and the case............now the screw gets in contact with a LIVE ungrounded conductor...the panel COULD possibly hold that voltage and not fault anything out........very possible... Not sure however as Richard stated that was the intent of the image...heck If I know........personally guys if a panel causes a ticker to light up....I would defer it.........ahhh......have Richard come look at it...lol... Sorry richard I could not resist Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
lol...are you trying to tease me tonight richard...lol...man I am in some kinda pissy mood...lol......in fact half the stuff I say tonight may be wrong because of my mood...lol......but I love ya brother......been a LONG day..lol
Because the resistance of the earth is so great ( 10-500 OHMS ), very little current will return to the power supply via the earth if the earth is the only ground fault return path...and floor as well in this case. The result is that the circuit OCPD will never trip....metal parts will and could become energized at a lethal touch point known as "Touch Voltage" and just waiting for someone to come in contact with it....
What is touch voltage- it is the potential difference between a grounded ( bonded ) metal structure ( ie:Panel ) and a point on the earth 3 feet from the structure. Many again think a ground rod can be used to reduce touch voltage, that is proven not true by the research done by the IEEE and NFPA. 1 Foot ( shell 1) has 68% resistance and touch voltage of 82V on a standard 120V connection.....so.....can 82 volts kill ya.... so we know if it is 82 Volts....and the resistance is say 25 OHMS......the amps would be potentially 3.28 AMPS....only takes 1/10th of an AMP to kill......if you are GROUNDED right..... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Paul
You and I are the experts Without going into my background - you have the NACHI blessing as the expert in electrical and as well as Joe T I can not put my trust in Mr Bell in this area - I can not see changing MOP for electricians and HI's to make this check Once again if I am wrong I will change my ways and I will start to require that all MOP that I sign off on have a check to see it the panels are hot Your call Pall -- is Mr Bell off base or not? rlb |
Tell the real estate agent there is a problem with the panel box. He will promptly tell you that you do not know what you are doing and just to show you how smart he is, he will remove the cover panel for you.
As for being an expert for NACHI....I think with the removal of me as a paid electrical speaker that your image of my position at NACHI is incorrect... I will leave JOE T as the only expert.....I am just here to give info.... SO what is your question for me again...I am getting LOST in my own posts tonight...lol Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| What happened to the daily... | klott | Miscellaneous Discussion for Inspectors | 25 | 5/21/07 12:44 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
| Is the daily doorprize now a "once in a while" doorprize ? | jthalmann | Miscellaneous Discussion for Inspectors | 7 | 12/1/06 12:34 AM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 2:48 AM |
