Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Question of the Day
Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: Stucco over Timber framing needs a control joint for every _______ sqft
100 10 43.48%
120 2 8.70%
144 9 39.13%
150 2 8.70%
Voters: 23. You may not vote on this poll
Old 11/21/06, 12:11 PM
gbeaumont's Avatar
Default QOD for 11/21/06 Stucco
Hi to all,
Here's todays question
Picture courtesy Carl "Mr BadStucco" Brown
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/21/06, 12:38 PM
Leonard E. Ungar's Avatar
Leonard E. Ungar Leonard E. Ungar is offline
Default Re: QOD for 11/21/06 Stucco
Gerry;
Not everyone can have a wall like that !!!!!!!!
Thank god;
Old 11/21/06, 8:38 PM
I think you are asking for the maximum typical spacing, no?
Larry Kage, CMI
231 929 3525
Old 11/21/06, 11:13 PM
gbeaumont's Avatar
Larry, there are several criteria to be taken into account with stucco, there is a maximum sqft area and also maximum height or width dimensions.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/21/06, 11:16 PM
gbeaumont's Avatar
Originally Posted by lungar
Gerry;
Thank god;
I hear you Len, unfortunately there are just not enough bad installers to go around, some people actually end up with stucco installed by people who know what the hell they are doing
Good god and I thought my humor was a bit on the dry side
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/22/06, 9:16 AM
Regards
Gerry
Yes, your question asks about square footage, which is typically area, so one would want the maximum...that's my thinking.
Larry Kage, CMI
231 929 3525
Old 11/22/06, 4:19 PM
I'm sooooo glad I don't have to deal with EIFS anymore!!!
Abraham Lincoln
Old 11/23/06, 9:04 AM
gbeaumont's Avatar
Hi to all,
The correct answer to this is:
144 square feet
Also no single dimension should be more than 18ft in length
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/23/06, 9:24 AM
Joseph Hagarty,  CMI's Avatar
Hi to all,
144 square feet
Regards
Gerry
For what types of stucco are you referencing?
Is there a Code or Standard that references the 144 square feet requirement?
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 11/23/06, 10:08 AM
gbeaumont's Avatar
Hi Joe,
the requirement is for cementatious stucco installed over timber framed walls a nd come from the ASTM std for stucco as referenced by most if not all cementatious stucco manufacturers installation instructions.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/23/06, 2:12 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Just for Reference:
Designation: C 1063 – 03
Standard Specification for
Installation of Lathing and Furring to Receive Interior and Exterior Portland Cement-Based Plaster1
7.11.4.1
Control Joints—Control (expansion and contraction)
joints shall be installed in walls to delineate areas not
more than 144 ft
2(13.4 m2) and to delineate areas not more than
100 ft
2(9.30 m2) for all horizontal applications, that is, ceilings,
curves, or angle type structures.
7.11.4.2 The distance between control joints shall not exceed
18 ft (5.5 m) in either direction or a length-to-width ratio
of 2
12 to 1. A control joint shall be installed where the ceiling
framing or furring changes direction.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 11/23/06, 3:28 PM
Thanks
Joseph P. Hagarty
Phone: 610-399-3675
Old 11/23/06, 6:30 PM
Carl A. Brown's Avatar
What the heck it is just stucco. Thats the least of the problems!
Old 11/25/06, 12:43 AM
The texture is very nicely done. We're seeing a lot of that here lately. They must have a new training class - You see so few quality installations like this.
Old 11/25/06, 7:49 AM
gbeaumont's Avatar
Dan,
This quality piece was done by "Wreckham & Skarper Installations" and is titled "Relief map of the moon" It was done in thier friday afternoon on the way back from the pub period, which is recognised as one of the best periods for random application art.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Need to ID type of stucco cdewitt Exterior Inspections 20 12/4/06 10:39 PM
Stucco course badair Inspection Education & Training 2 11/21/06 5:51 PM
Wisconsin stucco problem dnice Exterior Inspections 6 10/17/06 8:03 AM
Stucco and Building Wrap eyerise Exterior Inspections 5 6/29/06 8:35 AM
Stucco Inspection dlee2 General Inspection Discussion 7 4/3/06 8:17 PM
