| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: What two options listed are required for pool fences? | |||
| Gates should open in to the pool and should be self- closing and self-latching |
3 | 11.54% |
| Gates should open out from the pool and should be self- closing and self-latching |
23 | 88.46% |
| The gate should have no opening greater than ½ inch within 18 inches of the latch release mechanism |
8 | 30.77% |
| If the fence is chain link then no part of the diamond-shaped opening should be larger that 1½ inch. |
7 | 26.92% |
| Multiple Choice Poll. Voters: 26. You may not vote on this poll | |||
You can pick as many as you think are correct
Brian,
YOU HAVE MAIL! ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
What happened to the 4 inch sphere? I can honestly say that, without looking it up, I do not know the chain link rules. Probably against everything holy in pool safety since you can climb it.
If the third option is true, can someone interpret that for us?
Dylan...it's too early in the poll to start giving the answers away
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Ok Michael, I'll hold out. Thanks for the files.
2 and 3 are the correct answers. |
Ok Brian. Do you happen to know what 3 means? What is meant by an opening? Vertically, horizontally? These latches are typically on a gate, with lots of holes.
Quite frankly, I don't get it. Last edited by dbucknavich; 11/12/08 at 12:45 AM.. Reason: just cause |
Not exactly Dylan, I was hoping for someone to chime in and explain it.
I gave you the answers in post #5. I'd show it as an attachment here but this thread won't let me.
Hi Dylan, Barry sent me this, I believe Michael sent it also, I had trouble opening it. Use this guide when the release mechanism is located less - If horizontal members are equal to or more than 45 inches apart, vertical spacing shall not exceed 4 inches.than 54 inches from the bottom of the gate. - Fence gates should be self-closing and self-latching. The gate should be well maintained to close and latch easily. The latch should be out of a child's reach. - When the release mechanism of the self-latching device is less than 54 inches from the bottom of the gate, the release mechanism for the gate should be at least 3 inches below the top of the gate on the side facing the pool. Note: Placing the release mechanism at this height prevents a young child from reaching over the top of a gate and releasing the latch. Also, the gate and barrier should have no opening greater than ½ inch within 18 inches of the latch release mechanism. This prevents a young child from reaching through the gate and releasing the latch. |
| Pool Executive Charged in Drain Death | jhagarty | Ancillary Inspection Services & Additional Topics | 1 | 7/23/08 11:15 PM |
| This House Met Code. | jbushart | Electrical Inspections | 88 | 1/16/08 12:29 PM |
| Pentair Water Pool Gas Heater Recall | Gary Reecher | Inspecting HVAC Systems | 0 | 1/4/07 8:15 PM |
