| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: Water Pressure supplied by the city should be | |||
| At least 40 psi |
11 | 37.93% |
| not more than 100 psi |
1 | 3.45% |
| Not more than 80 psi |
16 | 55.17% |
| At least 15 psi |
1 | 3.45% |
| Voters: 29. You may not vote on this poll | |||
Water pressure
I know around here it is 50 psi, i should also mention our variables, elevation, pipe condition.etc
Dennis R.Goudreau D.R.G. Inspections LLC www.newhampshirehomeinspector.biz www.nhinfraredthermalinspections.com http://co.nachi.org/inachiawards Last edited by dgoudreau; 12/2/08 at 3:39 PM.. Reason: I want to |
"I like Astro Boy, I give him a 42 but I can't dance to it!" DPS
Verrrrrrryyyyy Interesting.... BK.....you are one schneeky one.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
I know Brian, but here the town is trying to take over the water supply company, they have been in court for 3 years about this. but good pressure wht is it in AZ
Dennis R.Goudreau D.R.G. Inspections LLC www.newhampshirehomeinspector.biz www.nhinfraredthermalinspections.com http://co.nachi.org/inachiawards |
8 bar perhaps????? |
Holy cow, 120 PSI is way too high unless each home is seperately regulated.
I think I learned some time back that nothing over 80 PSI was suggested, due to seals, washers and plastic parts that would be stressed by anything more. Am I out in left field here? Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
I think you're looking at 80psi here in Ontario, Canada.
Harold J. Lowe C.M.I., C.C.I. Eagle-Eye Healthy Home Inspections Sharondale Academy of Home Inspections www.healthyinspections.com harold@cannachi.org haroldjlowe@hotmail.com home-905-576-4337 cell-416-912-0852 CanNachi Director of Education Board Certified Master Inspector Certified Infrared Thermographer Pro-lab Certified Mould Specialist IAC2 Certified Indoor Air-quality Consultant Certified Commercial Inspector Toronto/Durham/Kawarthas Proud InterNachi Member # 06091197 |
Being newly educated in the art of inspection, 80 psi was taught to us. I have seen houses anywhere from 40-150 psi around here. Depends on how old the neighborhood is.
HLC Home Inspections Okla. Lic. #776 I am licensed Realtor with Keller Williams. Office Phone # 405-691-2708
"Water Pressure supplied by the city should be..."
Ahhh, a tricky little question. Water is supplied by the city both in the outside pipes and the inside pipes. Max inside pressure should be no more than 80PSI to protect seals in appliances. But, the external pressure must at least 100PSI to provide pressure for multiple houses. So, the water supplied by the city should be at least 100PSI, and the water regulated within the house should be about 45-65PSI. Regulators are normally factory set at a 45-65PSI tolerance, but should not be allowed to increase beyond 80PSI--and at the low end it should be at least 40PSI to properly service the average residence. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Or something like that...
I'm not buying it Jae. That's like saying I need 150 VAC on the incoming line to supply all the houses in my neigborhood with 120 VAC.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
