Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Question of the Day
Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: The most common problem with cast iron pipes is?
Cracks due to mechanical impact 5 2.16%
Leaks due to dried out hub seals 41 17.75%
Corrision from the outside 22 9.52%
Corrosion from the inside 163 70.56%
Voters: 231. You may not vote on this poll
Old 6/12/06, 9:29 AM
gbeaumont's Avatar
Default QOD for 6/12/06 plumbing
Hi to all,
Here's todays question
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/13/06, 11:05 AM
gbeaumont's Avatar
Default Re: QOD for 6/12/06 plumbing
Hi to all,
The correct answer is: Corrosion from the inside
Iron and steel pipes rust from the inside, with horizontal piping deteriorating faster than vertical pipes. the image in the question is of a cast drain that is 100 years old and rusted to the point of colapse.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 6/13/06, 7:00 PM
Richard L. Bennett Richard L. Bennett is offline
100 years -- not bad
Wonder how many years we can get out of pvc??
BTW something that will speed things up DRAIN CLEANER
rlb
Old 6/13/06, 7:18 PM
gbeaumont's Avatar
Hi Richard,
I agree the stuff does last pretty well.
This was an interesting one, the cast was on grade which always makes me take a closer look, and this one had a big gob of mortar on it that looked out of place, sure enough it had been to "repair" the waste pipe. That piece and I suspect many others will turn to dust when touched.
The point in posting that picture and this question was to make members aware that sometomes something that looks OK at first glance may actually be in very poor shape.
I recommend tapping on older cast drains they sound hollow when very rusty.
No one wants to end up liable for replacing that stuff, this was on a very large property and the replacement cost of those drains will be in the thousands.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 6/13/06, 7:20 PM
gbeaumont's Avatar
And yes before anyone calls me on it I know they are suposed to be hollow but you all know what I mean
Gerry
(Mark B Adams)
NACHI02121106
Old 6/13/06, 7:38 PM
Good eve Gerry
I did a very good Navy type of patch on one in my home when I moved in -- problem patch was perfict --- pipe was compleatly clogged -- a real big mess followed
10-4 on looking a little deeper -
rlb
Old 6/13/06, 8:01 PM
Brian E. Kelly's Avatar
Originally Posted by gbeaumont
Hi Richard,
Regards
Gerry
At 100 years old the entire system should be replaced as it is passed its life expectancy, IMHO.
Excellent questions Gerry, very much appreciated.
Old 11/1/06, 4:47 PM
aroncone's Avatar
aroncone aroncone is offline
Here's a link from the Canadian Research Council on "Failures in Gray Cast Iron Distribution Pipes." From the 60's to present, ductile iron was used in the mfg of cast iron pipes.
http://irc.nrc-cnrc.gc.ca/ui/bu/grayfailuretype_e.html
Aurelio Roncone, NACHI06020793
AccuSpec, Home Inspection Services
Windsor ON Canada
info@accuspec.ca
http://www.accuspec.ca
Not Just Service. Exceptional Service!
Old 1/11/07, 4:44 PM
Roy D. Cooke, Sr's Avatar
Great site thanks Aurelio
Much appreciated
Roy Cooke
Old 1/15/07, 8:40 PM
rwand1 rwand1 is offline
Looks like most of those answers would apply according to the NRC site.
Good link Aruelio
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 6:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 10:06 PM
