| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: Each service disconnecting means must be suitable for _________. | |||
| A.) Hazardous Locations |
1 | 3.13% |
| B.) Wet Locations |
5 | 15.63% |
| C.) Dry Locations |
0 | 0% |
| D.) The Prevailing Conditions |
26 | 81.25% |
| Voters: 32. You may not vote on this poll | |||
Enjoy.....
Each service disconnecting means must be suitable for __________. A.) Hazardous Locations B.) Wet Locations C.) Dry Locations D.) The Prevailing Conditions Paul W. Abernathy |
D. By golly Paul,. I got it right. Hah. not bad for a carpenter. ha. ha.
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
ok..now remove your answer so others wont cheat...lol
Paul W. Abernathy |
How do you tell if your poll answer is right?
Tom |
Nothing to say I am right, I am just right with the poll best percentage that you can look at before you vote. Right?
Carpenter Poll.... Which end of the nail goes in the board first?
Pointed ___ Flathead ___ Couldn't resist this opportunity, as a 30 yr. sparky. |
Randall;
Actually, I am quite busy on the job trying to figure out if the exterior existing lighting at 120v can be adapted to the new lighting circuit of 208v, and the possibilities of the doing so might be possible using the existing multi-tap ballast in the lamps of the existing yard lighting. I can drive a 16penny nail in three shots with a 12oz. hammer. ha. ha. You try it. Marcel </IMG></IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I can actually drive a 16 penny with one shot....but then again I use a nail gun.
Paul W. Abernathy |
The answer is D ( if you did not already figure that )
230.70(C) (C) Suitable for Use. Each service disconnecting means shall be suitable for the prevailing conditions. Service equipment installed in hazardous (classified) locations shall comply with the requirements of Articles 500 through 517. Paul W. Abernathy |
E, all the above.
lol...actually it gets quite tricky...since most service disconnects are dry locations...BUT not all are wet location units and most certainly not all are hazardous location worthy...so the answer ends up being ( and funny enough the code says it just that way ) the service disconnect must be rated really for the environment it is going to be placed in....
Believe it or not...I felt that was one of my better questions... Paul W. Abernathy |
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 3:58 PM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
| Chicagoland Electrical Code Ordinance | jtedesco1 | Electrical Inspections | 0 | 6/16/06 2:10 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 1:48 AM |
