| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: What is the minimum slope of a drainpipe? | |||
| 1 in 12 |
3 | 12.00% |
| 1 in 24 |
1 | 4.00% |
| 1 in 48 |
19 | 76.00% |
| 1 in 96 |
2 | 8.00% |
| Voters: 25. You may not vote on this poll | |||
Hi to all,
Here is todays question. Regards Gerry Picture courtesy Charles Buell "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry,
Thats one of those inline traps right. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Lousy supports and not enough of them . Roy Cooke
Hi to all
the correct answer to this is: 1 in 96 Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
says 7.4.8.1 Minimum Slope and length of Drainage pipes (1) Every drainage pipe that has a size of 3in. or less, and every fixture drain shall have a downward slopein the direction of flow of at least 1 in 50 Strange that there can be that much difference in our codes . Roy Cooke |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gerry,
This is from the IRC: "Drainage fittings shall be designed to maintain one-fourth unit vertical in 12 units horizontal (2-percent slope) grade." "Horizontal drainage piping shall be installed in uniform alignment at uniform slopes not less than one-fourth unit vertical in 12 units horizontal (2-percent slope) for 2 1/2-inch (64 mm) diameter and less, and not less than one-eighth unit vertical in 12 units horizontal (1-percent slope) for diameters of 3 inches (76 mm) or more." |
1/4" per foot for all drains min.
1/8" per foot for all Vents min. I even own a level for plumbing, it has a second set of markings for 1/4" per foot slope. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
It is very important to read the complete question. I failed to do that and choose 1/4 inch. This is the kind of question you have to look out for when taking a certification test.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
that was a little mean of me, but proves the point that Greg stated. This was one of those questions that is designed to be wrongly answered, and no it isn't a trick question, it is corrected worded. BTW, the full explaination is to be found in IRC 3005.3 or UPC 708.0 Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
| Plumbing Code changes | mcyr | Plumbing Inspections | 0 | 9/8/06 5:47 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 9:06 PM |
