| Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee. |
| View Poll Results: What measurement scale is "Absolute Zero" typically displayed? | |||
| Celsius |
3 | 9.09% |
| Kelvin |
29 | 87.88% |
| Fahrenheit |
1 | 3.03% |
| Voters: 33. You may not vote on this poll | |||
Let's start off with something relatively easy.
It is the temperature scale that actually falls on zero. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com Last edited by krichardson; 10/6/08 at 8:18 AM.. |
All Thermographer's should know this answer. If not, you need to go back to your books.
this was a good show/dvd, i'll let others reply with answer...although an ex-wife comes to mind
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 10/6/08 at 9:51 AM.. |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
I used to know a kid named Kelvin C. Farhrenheit.
Cool stuff to look forward to on a Monday. Thanks Kevin Mic |
No worries....they will get harder
Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Hi to all,
I'd like to thank Kevin for offering to help out with the QOD series and I look forward to many more IR related questions. Thanks Kevin Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
How about expanding this question to: "which temperature scales utilizes the same temperature difference"?
Celsius - Rankine Fahrenheit - Celsius Celsius - Kelvin Kelvin - Fahrenheit Rankine - Kelvin "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
We're going to start slow and work our way up to the more difficult questions. Your question above seems a bit misleading. What do you mean by "Temperature Difference"? Absolute zero can be defined as either 0 K or 0 R. Kelvin is equal to −273.15° on the Celsius scale Rankine is equal to −459.67° on the Fahrenheit scale Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
And here I thought it was when you were out of Vodka.
Thanks for starting off the IR questions on the easy side Kevin. |
If you have 100 degrees F (37.8 degrees C) and you add 50 degrees F, what is the degree rise in C? A 50F rise = 27.7C. Not that you need to know any of this in my question. A 100 degree rise in Celsius or Kelvin is the same as a 180 degree rise in Fahrenheit or Rankine. So the answer to the question is Celsius - Kelvin. What does this matter? Delta temps are sometimes listed in K. If they are talking about a 20 degree delta K, you know it is the same as a 20 degree delta C. Even though the temp value between K & C is 273 degrees different. Beleive it or not, I came across this last week and I had to think about it. Seeing everyone did so well, I figured food for thought would tide them over till next week! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Starting to sound like an Electrician David.
Sorry Brian! (and others)!
David I hope you know me better than that, no appologies necessary.
Dammed if even kicking and screaming I don't learn something from your posts. |
Your a smart guy But, your question is still misleading. What you are referring to is temperature "conversion." The true answer to your question is Celsius - Kelvin and Kelvin - Celsius and Fahrenheit - Rankine and Rankine - Fahrenheit Formulae: Celsius to Kelvin °C + 273.15 = °K Kelvin to Celsius °K - 273.15 = °C Fahrenheit to Rankine °F + 459.69 = °R Rankine to Fahrenheit °R - 459.69 = °F If you are converting Delta-T, then there is no change between °F and °R and °C and °K, as you have already indicated. However, if you are converting °C to °F or °K to °R, then it would be x1.8 or +1.8. It confused the crap out of me when I was first introduced to temperature conversions in Level II. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
I know.
I was very confused as well! That was the point. Just to think about it. You don't need to know all the math, just understand a little about what it is all about. Let me tell you, I have been called out on the carpet in front of several experts that know more than I. When you can convert K to C and explain it's relevance to F they will get confused as well. If your close or right, all discussion ceases. Just presenting yourself as understanding a little more than most is unreal! I'm not trying to test anyone's knowledge, just expose them to something that may save their hide sometime. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| IR/INFO 2008 Conference | krichardson | Thermal Imaging, Infrared Cameras & Energy Audits | 7 | 1/4/08 4:38 PM |
| 2008 NEC Code Quiz- 25 Questions | pabernathy | Electrical Inspections | 15 | 12/21/07 1:50 AM |
