Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Question of the Day
Inspection Question of the Day These are inspection questions posted daily by members of InterNACHI's Educational Committee.
View Poll Results: IR Radiation can be:
Transmitted, Reflected, Absorbed 2 13.33%
Reflected, Transmitted, Absorbed, Emitted 12 80.00%
Reflected, Transmitted, Emitted 1 6.67%
None of the Above 0 0%
Voters: 15. You may not vote on this poll
Old 10/13/08, 7:43 AM
Arrow Thermography QOD 10-13-2008
When striking an object, IR energy is similar to visible light with some exceptions.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 10/13/08, 7:53 AM
David P. Valley's Avatar
Default Re: Thermography QOD 10-13-2008
...reflected and absorbed by materials that are in its path.
Kevin, you edited your question.
Old 10/13/08, 7:55 AM
The more highly polished some surfaces are, the more IR energy the surface will reflect.
Old 10/13/08, 8:05 AM
The question has not changed. I just merely moved the "IR Radiation can be:" to from the body of the post to up in the poll area.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 10/13/08, 8:09 AM
Kevin
OK, I just jumped the gun a bit early.
Thanks for your time in coming up with the QOD.
Old 10/16/08, 12:47 PM
I'm surprised that no one answered this one correctly, but there were only 13 people who answered.
Anyway, the answer is "Reflected, Transmitted, Emitted"
Visible light can be "absorbed", while IR radiation can be "emitted"
E + R + T = 1.0
I'll have another on on Monday.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 10/16/08, 12:58 PM
Michael Larson's Avatar
How does your answer line up with this:
Infrared Interactions
The quantum energy of infrared photons is in the range 0.001 to 1.7 eV which is in the range of energies separating the quantum states of molecular vibrations. Infrared is absorbed more strongly than microwaves, but less strongly than visible light. The result of infrared absorption is heating of the tissue since it increases molecular vibrational activity. Infrared radiation does penetrate the skin further than visible light and can thus be used for photographic imaging of subcutaneous blood vessels
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 10/16/08, 1:34 PM
Well, I would say it doesn't line up with that statement. I'm no Physicist, but my question is basic IR Theory. More importantly, the Thermography QOD is designed for "Building applications" and home inspectors.
"The result of infrared absorption is heating of the tissue since it increases molecular vibrational activity."
The above statement is outside the scope of my knowledge. However, I do know that knowing the correct answer to a question based on ones training and experience verses looking up a page of information on the Internet can be quite different. I think you are comparing apples to oranges, IMHO.
Emittance is how well an object radiates IR energy when compared to a blackbody at the same wavelength and temperature. For most applications, Transmittance is usually zero, so Reflectance and Emittance are variables.
Absorbtion is not a factor in determining E R and T.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 10/16/08, 1:45 PM
Not trying to argue just understand.
I think the reason many chose absorbed is because we all feel the IR radiation of the sun as it is absorbed by our skin.
Can you provide a source of information that supports your question?
Michael Larson
Hudson, WI
InspectraPro
and
Old 10/16/08, 2:11 PM
David A. Andersen's Avatar
I think the question was not very clear.
BPI# 5015804
Old 10/16/08, 2:52 PM
E + R + T = 1.0
Kevin
Kevin,
IR radiation can also be "Absorbed" especially on black body objects. If a material absorbs all visible light (dull black surface), it is likely to absorb some of the infrared range as well.
Old 10/16/08, 4:53 PM
The way I understand it is:
Emissivity + Reflectivity + Transmissivity = 1.0
and E = emitter and/or absorber
Larry Kage, CMI
231 929 3525
Old 10/16/08, 5:19 PM
Correct: That which is absorbed is emitted. If it passes through or is reflected it can not be emitted. This is why T-Reflect options (which are not available on all cameras) is necessary to determine true temp vs. apparent temps.
The object always wants to go back to a state of rest (so to speak). As you add more energy it absorbs and then emits more.
David, not to nit pick but I would use the term gray body as a true black body does not exist. Some T or R will always occur.
Keep up the good work. It stimulates the thought process.
BPI# 5015804
Old 10/16/08, 6:24 PM
Thanks for everyone's responses!!
The whole premise to this question was to compare visible light to Infrared in order to get you thinking about the differences.
I think what we all are saying is somewhat correct, but the best answer to my question is what I have already stated.
An infrared camera uses colors to represent the thermal world it sees, just like we see colors visibly.
The BIG difference is colors in an Infrared image express both "reflection" and "Emission." When we are looking through our cameras at an object, "absorption" is not a factor.
This is directly form Level I Infraspection and FLIR/ITC Training manuals.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
IR/INFO 2008 Conference krichardson Thermal Imaging, Infrared Cameras & Energy Audits 7 1/4/08 4:38 PM
2008 NEC Code Quiz- 25 Questions pabernathy Electrical Inspections 15 12/21/07 1:50 AM
