Go Back   InterNACHI Message Board > General > General Inspection Discussion
LinkBack Thread Tools Display Modes
Old 10/5/06, 2:46 AM
Brian E. Kelly's Avatar
Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute Brian E. Kelly has a reputation beyond repute
Default Drip Pans
If the condensate drain leaves rust stains outside what do you think you will find in the drip pan?
"You got what it takes to keep the heads a-spinnin’ down by the old rim shack
And you come across just like a fool grinnin’ in the back of a red Cadillac"
ps some of the opinions I have posted here may or may not be factually based.
AZ Cert # 39975
AZ Pest # 050898
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 10/5/06, 2:51 AM
Dale Duffy's Avatar
Dale Duffy .
Default Re: Drip Pans
A model A Ford?...........
Old 10/5/06, 2:56 AM
Some shack in Scottsdale. Three homes today, all three had bad secondary pans. Splits were good though.
AZ Cert # 39975
AZ Pest # 050898
Old 10/5/06, 11:33 AM
David A. Andersen's Avatar
David A. Andersen .
I guess we need to spend more time on the pipe insulation thing!
If you didn't have a good split, you wouldn't have had the stain!
Old 10/8/06, 4:48 PM
Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute
Haven't seen condensate drains like that come out of the gable ends before.
Typically, from what I have seen, they are always roughed in to the rough framing and discharged directly above the box sill and extend far enough with a 45 degree elbow to not create these stains.
Most of the time it will be allowed to run the condensate to an indirect drain receptor that is close by. Then you would not have to worry about aesthetic stains on the exterior.
I have heard that condensate provides a chemical creating stains and rust, has anyone heard this?
Marcel
</IMG></IMG>
Old 10/8/06, 7:18 PM
Michael Larson's Avatar
Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute Michael Larson has a reputation beyond repute
Originally Posted by mcyr
I have heard that condensate provides a chemical creating stains and rust, has anyone heard this?</IMG></IMG>
Condinsate should be only distilled water or very close to it. The rust is most likely from the drip pan itself or other galvanized metal that has a damaged coating.
Old 10/8/06, 9:57 PM
In my opinion, it should not come out the gable end, correct?
Marcel
</IMG></IMG>
Old 10/8/06, 10:12 PM
Marcel
</IMG></IMG>
I'm not sure it makes a difference where it discharges. Window units discharge out their backsides to what's below.
Old 10/8/06, 10:52 PM
Marcel
</IMG></IMG>
That is the secondary pan condensate drain up high like that Marcel, the primary line comes out near grade.
If you have any water comming out of the high line it means trouble.
AZ Cert # 39975
AZ Pest # 050898
Old 10/9/06, 8:35 AM
David A. Andersen .
If you have contaminated condensate water, you have a serious indoor air quality problem!
It should not be discharged where it will cause any adverse effect to the structure (this includes the soil against the foundation).
Old 11/20/06, 3:00 PM
So what do you think the drip pan will look like once I get into the attic???
AZ Cert # 39975
AZ Pest # 050898
Old 11/20/06, 3:22 PM
Ok here is the attic.
It did get hot and cold though.
AZ Cert # 39975
AZ Pest # 050898
Old 11/26/06, 12:20 AM
Will Handley's Avatar
Will Handley Will Handley is offline
Will Handley .
You are correct Marcel, the discharge is "normally" located over a window or door to notify the occupant of the issue. In this case, "Out of sight, out of mind".....
They make some great pan mounted moisture kill switches that would put an end to that particular problem.
"I travel the globe to protect my clients"
Progressive Inspection Service
Orange County Home Inspectors
California Commercial Inspectors
Serving Los Angeles-Riverside-Orange
San Diego-San Bernadino-Imperial-Ventura
Kern-Inyo Counties and Baja California, Mexico
CSLB License #620475
MICB - Certified Master Inspector
Old 11/26/06, 10:01 AM
Greg Veal is generally well trusted
Condensate is a result of refrigeration condensing ambient (R.H) humidity into liquid. The water accumulated is a product of indoor air and rust is from contact with various metal components of the theoretical closed system.
That being said, I don't see the water being discharged to the outside being anywhere close to distilled, nor do I see it being any more caustic than the IAQ of the house the A/C system is conditioning.
We use to, by design, run the main drain line off the Evaporative Coil out with the Refrig. L/S, and the secondary or auxillary drain off the drain pan under the Furnace/E.Coil or AHU, out to and eave location over a prominent window or door location. The idea being that if the owner saw water dripping, they knew they had an existing problem or a problem starting with the HVAC system.
Action is needed, first, turn the system off as soon as you notice and secondly, call your HVAC service contractor. Algae and other gunk can grow in the various component pans and piping (due to lack of normal maint.) by the Homeowner/Svc. Contr., but I have never seen a real problem with the location of the drain discharge or the water.
Note: The discharge of the acidic condensate produced by a H/E 90%+ Condensing Furnace is different, and consideration to a discharge location may be more important, dependent on local codes.
Old 11/26/06, 7:05 PM
Joe D. Funderburk's Avatar
Joe D. Funderburk Joe D. Funderburk is offline
