| Inspection Hardware, Software & Publications What hardware, software, books, videos, etc have you found useful? What would you like to see more of? This topic is to discuss various inspection-related products and publications. |
What software are you guys using for your commercial reporting? I am looking to change what I am using for residential and am wondering if there is a program that works well for both, or if I should buy separate programs. I am really only doing light commercial normally less than 15,000 s/f and it’s only about 15% of my business. Any suggestions would be greatly appreciated.
Home Guage
Simply works the best for my needs....!! You can make any kind of template known to man or one not known to man...create what ever you want. I highly recommend HomeGauge for commercial and residential inspections. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Great. Thanks guys. Do you guys use it with a pocket PC?
I retired my pocket PC a couple months ago. It liked to crash on me after I had done a report. I switched to a laptop but still have the pocket PC version if I ever need it.
I'm to old...I need a 20 in. screen.............
HomeGauge...There is a Commercial Template already and you can customize it to fit whatever you need it to do. The software and support are amazing!!!
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
I use the Porter Valley Commercial reporting system, I also have the Porter Valley residential, personally I would not be without the PV Commercial as it is so flexible,however it may be over-kill for light commercial. The big advantage of PV is that you do not need a template, as you can add multiple buildings to a site, and multiple sections (locations) within a building on the fly, also the boilerplate comments include many areas that you would not see in residential software. Porter Valley Commercial also has things like Scope of work, Executive summary and probably/projected repair cost modules built in to it. I would suggest that you down load the trial versions of all the better software brands and "test drive" them to see which is the best fit. Feel free to give me a call if you would like a more detailed explanation. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 11/30/07 at 7:44 AM.. |
Thanks Gerry I am looking at it now.
While HomeGauge already comes with commercial retail, multifamily templates, HG is set to release the ASTM E 2018 commercial in the new 4.0 release this December (next month). The ASTM E 2018 template will cost $195 and will include a licensed copy of the ASTM E 2018 Standards. Russell Buchanan HomeGauge President Special $645 (Regularly $845) HomeGauge AnDroid* and the new HG Version 5 is released! HomeGauge in the past has always been neutral with all orgs...but there's no denying it, INACHI clearly provides the best value to its inspectors and is dominating ASHI, NAHI and the others in all areas when it comes to giving value to its customers.
| Commerical Reporting Software | rtrain | Commercial Inspections | 4 | 1/8/08 7:27 PM |
| New Construction Reporting Software Released fo rBeta Testing! Sign up today! | cdemsky | Inspection Hardware, Software & Publications | 14 | 6/3/06 11:51 PM |
| New Construction reporting Software Released for Beta Testing! Sign up Today! | cdemsky | Miscellaneous Discussion for Inspectors | 7 | 6/3/06 12:16 PM |
