| Inspection Hardware, Software & Publications What hardware, software, books, videos, etc have you found useful? What would you like to see more of? This topic is to discuss various inspection-related products and publications. |
I am new to the field and I am in the process of choosing a software, any suggestions??
What software do you use?(poll) Inspectvue Homegauge Bestinspectors.net Other |
http://www.nachi.org/forum/showthrea...ight=homegauge Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Same Here. Just finished a four bedroom home with defectos..
Easy to customize, Easy to use, Great people to deal with....HomeGauge.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
I use Inspector FX http://www.newimagesoftware.net/soft...pector_fx.html
I really like this program. You should check it out. If you want to test drive it just download it free to evaluate. |
lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
I like Home Gauge, I was going to switch this year, we were promised that the new InspectVue release was only weeks away, that was several months ago. If you are just starting out and don't want to spend the bucks for InspectVue or Home Gaouge, consider Report Host, no software to buy, pay by report, and they now have a version for your laptop. It's a great value. |
I like InspectVue, but after using it for 18 months, and then playing around with HG, it does seem pretty clumsy, the new version is supposed to fix that. |
Hey Lewis,
I too have been holding on in hopes of the new version, and have delayed investing in a different software. I have spent a considerable amount of time tweaking PV and still find it clumsy, and not very friendly. It has it's good points, but just like anything else today if it doesn't evolve, as promised, then it will surely die. Too many times I've heard "it won't be long now" and the only results liken themselves to "my dog ate my homework" syndrome, as if inanimate object like Vista could raise it's ugly head and personally destroy all the progress for the last year. I'll just wait, but like you I'll hold on to my 250 until some commitments are kept. |
Mark,
I switched 3 mos. ago to Interspect Voice. I've gotten several compliments on the reports. www.interspectvoice.com Bruce Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
Thanks for all your help everyone.
http://www.whispersolutions.com/ Cheers, Nolan E. Kienitz TREC # 7095 Nolan's Inspections, LLC 972-922-2111 - Direct www.NolansInspections.com Nolan@NolansInspections.com |
I Like Them. I use Inspectware.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Don't forget the AHIT.com report it plus
word based and works on pda as a backup you can have a few manual check box books in the truck in case battery death to finish the report and also XL Pro over at bestinspection, looked at the demo seemed ok never tried it though ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
Whatever you use, expect to spend a *lot* of time customizing it to your desired report format and style.
---------- One thing I like about Homegauge is that you can embed "smart-text" in other smart-text, this means for example that you can define and edit a component description list in one location and the changes will take effect in all other smart-text that you have set up to reference it. Another advantage of this feature is that you can build you own nested drop-down lists, strucuured and linked as you wish. For example the top level drop down list for "SFBA' can in turn pop up "Fireplace" and "Stove", and each of these in turn can bring up drop down lists for "Hearth/Extension", "Firebox", "Facing and Trim", "Clearances" and so on, and the "Firebox" list in turn can bring up a drop down list shared by "Stove" and "Fireplace", so if you are attempting to do real-time reporting on a PDA your drop down list at any point is never more than a few items long. And you set this up, not the Homegauge, so you can structure it pretty much any way you want - in this respect Homegauge (if you wish to use it this way) is a simple "programming language" as much or more than it's a conventional report "writer", and a template is a "program". OTOH, you don't have to use this nesting capability to produce a good report. |
| New Report Upload Technology | cdemsky | Miscellaneous Discussion for Inspectors | 49 | 5/1/07 10:19 AM |
| Texas report writing software? | arodriguez2 | Inspection Hardware, Software & Publications | 13 | 9/30/06 12:37 AM |
| ITA now includes NACHI's SOP in their report forms and reporting software. | gromicko | Inspection Hardware, Software & Publications | 4 | 4/8/06 9:05 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
