| Special Discounts for InterNACHI Inspectors This forum is a place for InterNACHI inspectors and affiliates to post special discounts and exclusive offers. This forum is publicly visible, but only InterNACHI inspectors can enjoy the discounts. You must have affiliate membership status to post advertisements on InterNACHI's Forum. To become an affiliate member, contact us. |
Nick,
that is a hell of a good price for any type of PP Co meter, my UEI one cost just under $300 dollars and is a bit bulky on the belt, if that is any good that is a bargain. regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
For most applications, 90% accuracy is acceptable and no maintenance is required. On startup, if the self check fails or low battery appears on the display, factory maintenance is required
HHmmmm battery has to be replaced at factory, wonder what the cost of that is |
One year (warranted). After one year we will discount your purchase of a new Pocket CO
by sending in the original. This way you may take advantage of the lastest generation of technology. Pocket CO is warranted to operate for 8 hours per day and 5 days per week for one year with no replacement of sensor or battery. Pocket CO will last longer with reduced usage. For example if you use it twice a week for a few hours in flight it may last 2 -3 years... I ordered one, it should give good service for the price. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mike,
I think it looks like a good deal, too. Get back to us soon and let us know if you like it or what its limitations are! |
What "latest generation"? CO doesn't change so why should the meters, unless of course they get smaller. David Nice National Certified Inspection Services, Inc. Wauwatosa, WI http://www.nationalcertified.com 414-979-6900 President WiNACHI http://www.winachi.com Wisconsin InterNACHI Chapter |
BTW don't you live in a high heating load state??? Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
cradan is a non-member guest and is in no way affiliated with InterNACHI or its members.
It actually seems like a great deal. I couldn't help but notice, however, that its temperature operating range bottoms-out at 32 degrees, F. Assuming you need to zero the little bugger to outside air, can those of us in the frost belt assume it would cag periodically...or worse, permanently? I'm thinking January 27th in Chicago? Perhaps December 30th in Buffalo or Massena? Say, February 8th in Bangor. February 20th in Missoula? Just about any time in International Falls or up in the yoop? Not to mention our friends in the Provinces. Brrrrrrrrrrrrrrr.........
I'll let everyone know how it works in the frozen Low Country around Charleston
I am sure if they made one with batteries that can be replaced they would fly off the shelves. It may be cheap on the short run but on the longer term it may be worth it to go with a pricier unit. David Nice National Certified Inspection Services, Inc. Wauwatosa, WI http://www.nationalcertified.com 414-979-6900 President WiNACHI http://www.winachi.com Wisconsin InterNACHI Chapter |
Hi, I saw your Pocket CO comments on this board and thought I would clarify some of the questions. Here are some comments from the inventor:
1] MOST DISPOSABLE TECHNOLOGIES LAST 90 DAYS ... THE POCKET CO IS MADE TO LAST A YEAR FOR $129 ($119 NACHI special) ... SECOND YEAR AT <1/2 THE ORIGINAL PRICE ... EVEN WITH A $300-500 METER YOU NEED TO CALIBRATE AND REPLACE SENSOR PERIODICALLY ... WE DO THIS EACH YEAR AND INSURE THAT YOU HAVE A FRESH BATTERY AND CALIBRATION FOR USE THE NEXT YEAR .... IF I WERE USING IT TO PROTECT MY LIFE I WOULD WANT A PERIODOC CALIBRATION OR BUMP TEST OF THE DEVICE 2]IN COLD TEMPERATURES WE HAVE USED THE POCKET CO ... WHEN IT GOES BELOW 0, WE JUST HOLD IN IN OUR HAND OR POCKET AND IT WARMS UP [SOMETHING YOU CAN'T DO WITH LARGER UNITS .... ].... I look forward to hearing more about how things are working out with Pocket CO. It is truly a breakthrough in detection devices. Mary Maclay NACHI special til Feb 14th at www.quantumfields.com/NACHI2006 |
Update,
Been wearing it in my shirt pocket (camera sits right on top of it!) I turn it on for an 8 hour test cycle prior to the start of each day's 0900 inspection. Wear it through that and the 1300, haven't had a reading over 2. One note, the beep (or beeps) that warn you when readings become high is very quiet, so I find myself pulling it out and checking when I'm looking in a gas forced air unit... works well so far. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Structural Inspections | 3 | 10/31/06 3:17 PM |
| How to avoid so many spammers | wforsyth | Miscellaneous Discussion for Inspectors | 67 | 10/30/06 9:03 AM |
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Interior Inspections | 6 | 10/29/06 5:35 PM |
| For Sale Nokia N80 For A Cheap Price Of $150usd | tonystores | General Inspection Discussion | 1 | 10/27/06 11:34 PM |
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Legislation, Licensing & Legal Issues for Inspectors | 1 | 10/27/06 11:31 PM |
