| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
I recently did a new home inspection and was surprised that the 2nd floor laundry closet does not contain a floor drain or pan. Does anyone know if this is a code requirement.
I would consider having a drain to be "good building practice" but not sure if I can push the builder to have this done as a code violation. |
I have seen many new homes without pans. Which leads me to speculate that it is not a code requirement. However it does seem short sighted given the location of the washer/dryer being located other than in the basement.
Retrofitting a pan/drain line might be more costly than its worth. You might wish to recommend that the hot/cold feed lines be metal braided to prevent burst feed lines, which are the bane of high rise dwellings. |
or recommend that automatic shut off valves that are activated when the washer is turned on. They are installed directly onto the existing taps, no hoses in between.
I may not be 100% correct but, in my area a floor pan and floor drain are not required if the washer is to be connected to a direct drain. If the washer is going to drain into a laundry tub (not it's own drain) then a floor pan and floor drain are required.
The most logical reason is a direct drain for a washing machine (2" min.) should not clog... the hose connected to the washer is smaller and would clog not letting it to drain at all. If draining in to a laundry tub all it takes is someone soaking some cloths or other item falling into the tub blocking it from draining. The tub then overflows when the washer drains. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
Washing machines and dishwashers are prone to leaking. Usually when you are not home!
Anytime they are located above a finished ceiling they should have a drain pan. In my humble opinion. Last edited by vmitchinson; 5/13/07 at 12:24 PM.. |
I've run into this quite often as well. I advise the clients to use braided washer hoses and to get into the habit of turning the taps off when the laundry is done.
Just plain scary to me but, that's just me Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
| Flue through bedroom closet | rwills | Interior Inspections | 7 | 2/1/08 6:40 PM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 10:48 AM |
| water heater at interior closet | bking | Plumbing Inspections | 1 | 2/14/07 10:03 PM |
| Heat Pump airhandler in basement closet | ccowles | Inspecting HVAC Systems | 8 | 11/15/06 8:44 PM |
| Combustion Air Availability? | cradan | Inspecting HVAC Systems | 4 | 2/19/06 9:16 AM |
