Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 4/27/11, 9:17 AM
Ken Peckham Ken Peckham is offline
Default AFCI-protected Requirments
Hello,
Can someone confirm what the current Canadian elec code is for AFCI-protected rooms.
I'm reading one of the NACHI courses and is states that "All 15- and 20-amp 120-volt circuits for dining rooms, living rooms, bedrooms, sun rooms, closets, hallways, or similar areas must be AFCI-protected". However, I believe the current code requirment in Canada is different requiring one for bedrooms.
Thanks,
Ken
Need a home inspection in British Columbia? Check out InterNACHI's listing of British Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/27/11, 9:34 AM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Default Re: AFCI-protected Requirments
From another (Canadian) inspection forum:
Arc Fault Circuit Interrupters will only be required for new construction, and additions or renovations when a new circuit is provided for a bedroom. AFCI's will not be required when existing receptacles are simply replaced.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 4/27/11, 10:05 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
I recommend GFCI on none grounded plugs in the bedroom and an upgrade of 1 AFCI if a ground is found in the bedroom closest to the bed.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/27/11, 1:51 PM
OK, Thanks guys!
Old 4/29/11, 12:26 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Stop by your local home reno store and pick up a copy of the Residential Electrical Code. it cost about 16.00. It is the bible for the nation electrical code.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
Old 4/29/11, 1:11 PM
Banned
Originally Posted by kpeckham View Post
Hello,
Thanks,
Ken
In new construction and in re-wiring of a home, all receptacles in bedrooms are required to be AFCI protected.
Old 4/29/11, 1:15 PM
Banned
Originally Posted by kwood View Post
I recommend GFCI on none grounded plugs in the bedroom (whole circuits would be protected with GFCI breakers at the panel) and an upgrade of 1 AFCI if a ground is found in the bedroom closest to the bed.
Old 4/29/11, 1:21 PM
Banned
Is that the version by P. S. Knight, the former electrical inspector. If so, it may only apply to Alberta, Sask, Manitoba, NB, NS & NFLD/LAB.....those must be the jurisdictions that adopt the CEC "as is" without any changes.
Old 5/1/11, 8:09 PM
My latest copy says on the front page.
"Alberta Book 1"
"Electrical Code Simplified"
"Residential Wiring"
"Based on the 19th Edition of the Canadian Electrical Code and Alberta Amendments"
It is copyrighted 2002 and I purchased it on 2006.04.09.
Quote from the book 'Bedroom plug outlets- Rule 26-722(f)(g) now require special protection for circuits which supply plug out lets in the "sleeping facilities of a dwelling unit." These are called arc-fault circuit interrupters". .... Every plug outlet in any room where there are "sleeping facilities" must be protected with this special kind of circuit breaker. '
Registar
AlbertaNACHI
Old 5/1/11, 8:45 PM
Banned
"Alberta Book 1"
The copy that I have is copyrite 2006 and I've had it for 3 years. It's based on the 20th edition (2006) of the CEC. ......Is Alberta behind in code editions?
The 21st edition (2009) of the CEC is now in effect here as of 6-8 months ago.....guess I got to drop another $200 for that + the $16 for the "simplified" book!!
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
AFCI protected exterior GFCI srowe Electrical Inspections 10 6/7/09 8:46 PM
How do you verify smoke alarms are AFCI protected? jfunderburk Electrical Inspections 6 1/24/08 10:48 PM
AFCI's Explained by Mike Holt & Eaton Engineer pabernathy Electrical Inspections 19 2/15/07 12:05 PM
