Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 1/26/10, 7:39 PM
Kevin T. McDade's Avatar
Kevin T. McDade Kevin T. McDade is offline
Default AFCI' s
I have have just moved into new house. Afci only in bedrooms. Nec says all 15 and 20 amp circuits must be Afci.
Is this only an american thing. Confused in Canada.
Can't find answers
Need a home inspection in British Columbia? Check out InterNACHI's listing of British Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/27/10, 3:02 PM
Mazyar Esmaeiliyan's Avatar
Mazyar Esmaeiliyan Mazyar Esmaeiliyan is offline
Default Re: AFCI' s
Hi Kevin:
Canadian standard says, Branch circuits that supply receptacles installed in sleeping facilities of a dwelling unit shall be protected by an AFCI. Canadian Electrical code 26-722 (C.E.C) book. It is not a big deal if you have it in your panel box you should check it every month or every two months to be sure they work properly.
Take car
Maz
Old 1/27/10, 4:25 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Default Re: AFCI' s
I have heard rumours to the effect that it may be required in the near future. But Mazyar is correct.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 1/27/10, 4:34 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Re: AFCI' s
AFCIs
Find a Home Inspector
Old 1/27/10, 9:50 PM
mellison's Avatar
mellison mellison is offline
Default Re: AFCI' s
Yes, Mazyar and Claude are right. As Claude states; something appears to be changing with electrical code in Ontario, but I haven't been able to track down any facts. I've seen new tamper resistant receptacles in 2 brand new builds which, I thought, wasn't yet required in Ontario.
Old 1/28/10, 1:41 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Default Re: AFCI' s
I have this tester. http://www.nachi.org/afci-indicators.htm It also measures circuit resistance. Since the approval of plastic water supply pipes the electrical panel must be grounded with a ground rod or plate. When they are not visible I test the wall socket closest to the panel for ground and neutral resistance.
It is recommended that maximun ground and neutral resistance for electronic equipment is 0.25 ohms and max. 1 ohm for all other uses.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
AFCI Controversy rcooke Electrical Inspections 11 9/10/07 2:14 PM
AFCI's Explained by Mike Holt & Eaton Engineer pabernathy Electrical Inspections 19 2/15/07 12:05 PM
