Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 7/24/10, 12:23 PM
pmassie's Avatar
pmassie pmassie is offline
Please Note: pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Almost ended up in a fist fight with contractor
Hi Guys!
I did a home inspection yesterday that almost ended up in a fist fight between me and the contractor. see the pics below and tell me what is wrong here
ok, first ting : flooring. presswood is good for flooring he said....then i said show me de drawing (plans) and he did. on the plan it was mentionned : use plywood 5/8 thick....then he went nuts....
for the other pics , tell me what you see....
(Client was REALLY HAPPY)
Need a home inspection in British Columbia? Check out InterNACHI's listing of British Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/10, 1:22 PM
Banned
Default Re: Almost ended up in a fist fight with contractor
Originally Posted by pmassie View Post
Hi Guys!
Immediately.......take INACHI's self-defense series of courses!!!!
He is nuts if he substituted the subfloor material without a change order. It's not like OSB board is a bad subfloor but to try to slip in a cheaper product without the homeowner's permission......NUTS, he is!!
Attachment 38126
Attachment 38127
Attachment 38128
Attachment 38129
Attachment 38130
Looks like the butcher.......er......plumber should be in the meat trade.
Was installing an HRV in a new home for an aquaintance 3 years ago. The plumber......er...butcher had cut though 3- 2x8" floor joist for his 3" toilet drain. Called the owner who called the inspector and a fix was agreed on. The plumber was a part-timer whose day job was.......you guessed it....a butcher at a local supermarket!
Old 7/24/10, 3:15 PM
cboyd cboyd is offline
Please Note: cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
Should note that duct tape plumbing repairs should not be made until the house is at least 10 years old.
Old 7/24/10, 3:18 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
I would think 3/4" T&G OSB is better than 5/8 ply. Looks like the only good thing he did
Old 7/24/10, 3:33 PM
Bert B. de Haan Bert B. de Haan is offline
I have no problem with T&G OSB subfloor. Not if the specs call for plywood though. Some of the other defects are great. I especially like the notch in the beam.
Benchmark Home Inspection Services.
http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection
Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas.
Old 7/24/10, 4:00 PM
Bob Elliott's Avatar
Though allowed in I joists.
Old 7/24/10, 4:07 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
A notch?
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 7/24/10, 5:29 PM
Originally Posted by rnewland View Post
A notch?
No,of course not.
I was referring to the web.
Old 7/24/10, 5:31 PM
No,of course not.
I was looking at the notch in the first picture.
Old 7/24/10, 5:44 PM
What makes it laughable is that right next to his DIY patch job is a slice clear through the bottom of that Ibeam.
I am glad not to see those type beams around here much.
First minute I saw the darn pic I had to figure out why they had joists going perpendicular to each other before I realized it was a cheapo version of a real beam (haha) .(sorry I hate those I beams)
Old 7/24/10, 5:58 PM
wnapier's Avatar
wnapier wnapier is offline
Please Note: wnapier is a non-member guest and is in no way affiliated with InterNACHI or its members.
But it's a NEW house, what could be wrong to need an inspection?
Bwahahahahahahahaha...............
Al (have heard that many times in the last 20 years) in TN
Old 7/24/10, 8:43 PM
Marcel Gratton's Avatar
Bob,
Are those Gluelan, Laminated Timber that much cheaper than those real Ibeam?
Curious mind wants to know,
On The Level Inspection
Gatineau, Québec
Old 7/24/10, 8:56 PM
Joe Funderburk, CMI's Avatar
I do see what appear to be defects in notching of the joists.
However, I hope you didn't use the term "presswood" in your report or oral conversations with the contractor/client. It's OSB, as in Oriented Strand Board and it is much more commonly used than plywood these days.
Number 2: If you aren't an engineer with special training in wood characteristics, I don't think you're qualified to call out as a defect the use of OSB as a flooring material, even if it does contradict the plans. (If that were the case, 95% of the homes here are defective. Here's a good article about OSB vs. Plywood.) Does your jurisdiction have a code enforcement office? Just a thought, but perhaps you should have just documented what you saw and called them to inquire about the acceptability of this material. Or, referred the buyer to the home designer about the apparent contradiction and the ramifications of it.
Number 3: The holes in the I-joists, with some exceptions, are permitted. Just because the hole isn't cut beautifully isn't necessarily a defect. Unless you already know the manufacturer's specifications, a little research in this area may have been prudent before scaring the buyer.
Inspectors have to be very careful, especially when inspecting new construction. Times are hard and buyers are hard to come by. If the deal falls apart based on unsubstantiated or inaccurate allegations from a home inspector, a pissed off builder with the proper financial resources could put you out of business by tying you up in court for years to come.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/24/10, 8:57 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Notched beam at bottom with a piece of protective wood was a nice touch. Square opening in TJI was nice, as was the splintered look of the opening this idiot put in the adjacent TJI. But, from a purely technical standpoint, all may be okay.
Backpitch to the ABS was a beautiful thing, but not as great as substituting what the plans called for in the way of OSB flooring for plywood. OSB is an accepted flooring material, BTW.
I'll bet dollars to doughnuts that squash blocks werent installed at TJIs beneath point loads and bearing partitions...
BUT... Mr. Funderbunk's commentary is spot-on...
Love the commentary, Big Joe... Bravo.
Old 7/24/10, 9:02 PM
Another strange thing: all that ABS piping. 99.99% of what's used here is PVC now.
Theodore Roosevelt
Joe Funderburk, CMI
Beware the thermal imaging contractor phenderson Thermal Imaging, Infrared Cameras & Energy Audits 29 2/8/09 4:48 PM
John McKenna and Nick Gromicko debate licensing and have a fist fight caught on tape! gromicko Legislation, Licensing & Legal Issues for Inspectors 10 4/24/08 10:06 AM
Go & Get 3 Bids, Advice Article written by Ed Ed Fako Exterior Inspections 2 5/25/07 7:58 PM
