| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
Anyone (old enough to) knows what that liquid filled glass apparatus purpose in life is?
Is was located in the basement of a centenial home. Thanks, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Find an InterNACHI certified Alberta Home Inspector (and anywhere else in North America) |
It is a fire grenade, and the liquid inside it is extremely unhealthy...
Major Concern... Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
The one I saw was in 'Haliburton Lodge" on Drag Lake in Haliburton Ontario. The base was made to melt and drop the globe on the floor. I guess if it didn't put out the fire you had a good chance of expiring from cancer from exposure to the contents!
Thanks!
It looked like water inside when moved; luckily, that spring loaded mechanism at bottom wasn't activated... Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Carbon Tetrachoride. This is the grandfather to the newer Halogen fire extinguihers. Was developed during the war years.
The idea was that the fusable ink would go off when heated and break the globe but as Mark says, they became like a fire grenade and were tossed at the fire to put the fire out. Allan Berdahl Aarlan Home Inspection Services Calgary, Alberta Bus: 403-808-5355 Cell: 403-803-4064 Fax: 403-204-8863 Email: aarlan@telus.net |
Wow!
I have never seen one. Thanks for the photo and info guys. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
I actually learned about them, right here on this message board. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Just out of curiosities sake. How would one dispose of these things if they are such a hazard? Other then tossing them at agents.
Joe Hagerty used to find a lot of them.
http://www.nachi.org/forum/f18/fire-grenades-12568/ Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Best and least expensivee way to rid a home of these is to contact the local fire department and they will remove and dispose of. They know the dangers of this stuff and handle accordingly. Have removed many in my time and this stuff can be lethal.
Although that agent thing . . . . . . I'm just sayin'
I could be wrong but if memory serves me right back in the sixties the drafting office I worked in used Carbon Tetrachoride to clean our equipment. I found out later that this stuff went right through your skin into your body.
Vern Mitchinson_CCHI_CMI Registar AlbertaNACHI International Association of Certified Home Inspectors of Canada
Yep i haven't seen one of those for a long time, Check with the owner it might be a collector , it should not be in service or have the liquid inside though. Yes the phone company used Carbon Tetrachoride to clean the switch gear also had gallons of the stuff around. I think halon extinguishers are also been discontiuned in Canada. does anyone know how to tell them?
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 6:46 AM |
| Cleaning Whirlpool Baths or Bathroom Spas? | kkenny | General Inspection Discussion | 29 | 3/14/07 12:36 AM |
