Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 11/19/06, 1:11 PM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
Default Backwater valve in new homes?
Hi everyone, talked to this fellow and Just got this e-mail and wanted to
find out for sure what is what with the backwater valve.
Subject: Backwater Valve in new homes
> Hi Chuck,
> We just chatted on the phone and I already want to thank you for taking
> the time and answering my questions.
> My question is if Ontario has a requirement in the building code making it
> mandetory for new homes to have a backwater valve and if a properly
> installed backwater valve is something that we can check or verify the
> presence of.
> As I said over the phone it looks as though this is code in Manitoba and
> this web site shows that home owners in Manitoba ( at least in Winnipeg)
> are able to inspect and clean out their backwater valve.
> http://winnipeg.ca/waterandwaste/sewage/basementFlooding.stm
> Of course I do understand as well that winnipeg is a flood plain area and
> they would have strickter requirements on this type of thing.
> Thanks again,
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 11/19/06, 3:33 PM
Rob A. Parker Rob A. Parker is offline
Send a message via ICQ to rparker
Default Re: Backwater valve in new homes?
Chuck to answer your question 7.1.7.2 ontario code Accessibility (1) every fixture ,plumbing appliance ,intercepter,cleanout,valve,device or piece of equipment shall be so located that it is readily accessible for use,cleaning and maintenance.This is from the 1997 code book
Rob
Rob Parker RHI CMI
ITC Level 1 Thermographer
Thamespec Inc.
www.thamespec-inspections.com
Old 11/19/06, 3:42 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
about all you can check is to see if its installed in the right direction of the flow. It should have and arrow on it indicating the direction. I'm assuming your talking about the drainage system here, and there is usually a compartment covered with wood or metal plate in the concrete floor close to the main clean-out. In our area, they place a sticker on the electrical panel to let the home owner know if one has been installed in the home.
If your talking about a back flow preventer in the water supply system, these too can also be installed backwards...just check for the directional arrow for correct installation.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 11/19/06, 3:54 PM
wjung wjung is offline
Please Note: wjung is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chuck,
although I think it's a really good idea if one bulds a new home to install one, to the best of my knowledge there is no building code requirement in Ontario for new homes to have a drainage back flow prevention valve. However, if someone knows the relavant code section I could be proven wrong. Have not look at code in quit some time.
Wolf
Old 11/19/06, 6:05 PM
Vern Mitchinson, CMI's Avatar
Vern Mitchinson, CMI Vern Mitchinson, CMI is offline
This device was invented by a chap in St Albert, Alberta and is required on all new homes in St Albert. It is recommended by the City of Edmonton. It can only be installed with the flow in the correct direction, If it is installed backwards it will stop the flow. It is designed to allow the sewer to vent and water to flow through. The valve is activated when water flows back. It shuts off. Hence the name "back flow preventer". All other valves are called check valves at lease that's what I call them just to keep it straight in my mind. Thus I know what I'm talking about.
I would be interested in knowing what other municipalities require them.
I think they should be added to all the building code
Old 11/20/06, 3:27 AM
tmels tmels is offline
Please Note: tmels is a non-member guest and is in no way affiliated with InterNACHI or its members.
i don't think that it is code but most comercial buildings in peterborough area the insurance companys are making it manditory that they install backflow preventors. No backflow preventor no insurance. That could be starting to flow toward residential as well.
Old 11/20/06, 1:01 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
The code seems to be a bit ambiguous on the subject.
7.4.6.4. says
1 A backwater valve or a gate valve shall not be installed in a building drain or in a building sewer.
2 Except as provided in sentences 3 4 and 5 where a building drain or a branch may be subjected to backflow a gate valve or a backwater valve shall be installed on every fixture drain connected to them where the fixture is located below the level of the adjoining street.
I think that sentence 5 is the pertenent one here.
A subsoil drainage pipe that drains into a sanitary drainage system that is subject to surcharge shall be connected in such a manner that sewage cannot back up into the subsoil drainage pipe.
On one hand it says no and then gives 3 or 4 reasons to have them installed.
Larry
Old 11/21/06, 8:22 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
7.4.6.4. says
Larry
What Larry said plus; Appendix "A" A-7.4.6.4.[1] and A-7.4.6.4.[5]
The appendix clarifies this further.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 11/21/06, 12:01 PM
Only clarifies for the ones that have the book?
Old 11/21/06, 1:55 PM
lewens's Avatar
Appendix
A-7.4.6.4.(5)
Protection From Backflow Caused By Surcharge
These requirements are intended to apply when in the opinion of the local authority having jurisdiction there is a danger of backup from a public sewer.
So I guess it is up to the local authority as to when and if a backwater valve is required.
Larry
Old 11/21/06, 1:56 PM
lewens's Avatar
Chuck
If you ever need the "book" call me and I will loan you mine.
Larry
Old 11/21/06, 5:57 PM
Charles
E-mail me your address and I will put one in the mail for you.[ Part 7 Plumbing Code book]
Tel.# 416-722-6132
Old 11/22/06, 11:45 PM
dsmith1 dsmith1 is offline
You may want to advise your clients to check with their individual municipalities. The city where I live passed a bylaw that states all homeowners must install a backwater valve at their expense if they do not have one. They also stated that as of a certain date they would no longer compensate any one who did not have a backwater valve and who was flooded because of a city sewer.
http://ville.saint-lazare.qc.ca/docu...694_notice.pdf
I think it's a good idea to recommend one even if not required by law.
Old 11/27/06, 2:54 PM
Charles
Thanx Mario, I owe you one.
Old 11/28/06, 12:28 AM
Charles
Your welcome.
I hope you received it today, Canada Post said that it would be delivered today!
</IMG></IMG>
Tel.# 416-722-6132
Learn the Differences: Site-Built, Modular, Manufactured/Mobile Homes jsieg General Inspection Discussion 10 12/23/07 12:20 AM
Toxic Gas in Mobile Homes jbushart Miscellaneous Discussion for Inspectors 0 11/12/07 9:31 PM
Grab Your Checkbooks - For sale: 2 million empty homes jburkeson1 Miscellaneous Discussion for Inspectors 2 10/26/07 8:22 PM
Mortgage crisis hits million-dollar homes jburkeson1 Miscellaneous Discussion for Inspectors 3 3/29/07 6:04 PM
