Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 11/29/08, 2:32 PM
Default Clothes Dryer Circuits in Ontario
I just wanted to pass on some info I recently received in case there are some Ontario inspectors who may not already be aware of it.
Three of the last five homes I inspected, all 70's and 80's vintage, had dryer circuits comprised of 40A breakers and #10 copper wire. I called for further evaluation because a 40A breaker requires #8 wire, but I also thought this was too much of a coincidence so I contacted the ESA.
They advised that, over some period in the 70's and 80's, it was acceptable to the ESA to have a 40A breaker on #10 wire for this application. The reason - some very powerful dryers were being produced over that period causing nuisance tripping of 30A breakers.
Dryers now must consume 24A or less and therefore only 30A breakers are allowed for the #10 wire used today.
It still leaves me a little confused about what I should be writing when next I find a 40A breaker on #10 wire in an older house.
Old 11/29/08, 2:53 PM
cboyd cboyd is offline
Please Note: cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Clothes Dryer Circuits in Ontario
Since those dryers with nuisance tripping would be long gone now we could just note that it is recommended a 30 amp breaker be installed at some point when we see #10 wire. A short explanation, verbal and in the report as to why we comment on it this way. Good point to bring up.
Old 11/29/08, 6:56 PM
dcook1's Avatar
dcook1 dcook1 is offline
Please Note: dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Charles got it on the first try.... definitely explain to the client they should change it for safety. Remember, if they don't (and probably won't) at least you have told them.
Old 12/1/08, 2:06 PM
William R. DeVries, CMHI's Avatar
William R. DeVries, CMHI William R. DeVries, CMHI is offline
As this is not a code specific inspection, during the 1970 -1980's the Electric safety Standards allowed the Branch circuit have 40amp on a #10 gauge wire. It's reason as per ESA was the dryers then were less efficient and had a much heaver consumption. Todays dryers are " Energy Star" Compliant and inasmuch use less electricity. If your current dryer is an "energy Star " Compliant model it is recommended to have this circuit changed to todays electrical codes. Recommend electrician repair or replace as needed. This is for your information
ASNT Certified Level II Thermographer
Certified Mold Inspector (Pro-Lab)
Certified Mold Inspector IAC2
Certified Home Inspector INACHI 07040201
Commercial Property Inspection
Certified Master Home Inspector
2008 InterNACHI member of the year
Magnum Property Inspection
Inspect it before you buy it
613 813 2353 mobile
We use and recommend
Home Inspector Pro Software
HomeGauge Software
Dryer sheets potential hazard badair Miscellaneous Discussion for Inspectors 15 7/9/11 2:39 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 9 9/9/07 7:02 PM
Tarion, Ontario New Home Warranty Program. ccrooker Canadian Inspectors 0 2/9/07 7:46 PM
