Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 1/8/09, 2:00 PM
Default Cold Air Returns
What is allowed to be run inside cold air returns i.e. wiring, plumbing, central vac, gas piping, etc? I'm guessing "none of the above" but I'm having a "discussion" with a builder so I need a code reference (Canadian).
Old 1/8/09, 4:00 PM
David A. Andersen's Avatar
Default Re: Cold Air Returns
Call your code department.
HI's are not code enforcers.
Should that crap be in there, No.
But who's to say.
BPI# 5015804
Old 1/8/09, 4:24 PM
Wayne B. Wilson's Avatar
Nothing should be allowed. I would refer it to the local fire inspector. or building code official
Old 1/8/09, 4:54 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
I've seen just about everything running through COLD air returns and joist runs...I don't think there is any restrictions on this. The onlything I would watch for is electrical (110 volt) as it passes through a metal duct, this should have some type of bushing to protect it from sharp tin edges.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 1/8/09, 5:01 PM
David P. Valley's Avatar
Originally Posted by jallingham View Post
What is allowed to be run inside cold air returns ?
Return air and return air only. I can't count the times I found other items running through these ducts.
How about this return air duct, stuffed with insulation. I knew something was wrong when the return plenum door slammed shut when I was attempting to pull it off...
Old 1/8/09, 5:09 PM
Terry Clayton Terry Clayton is offline
there are some circumstances where the AHJ and the municipal codes allow the placement of electrical and plumbing to cross cold air returns (NOT RUN WITH THEM) COLD AIR ONLY. The penetrations should be sealed
Old 1/8/09, 5:18 PM
I am very sorry for my post I saw after I posted you were in the North Country I have no experience that far north sorry again
Old 1/8/09, 5:23 PM
Charley L. Bottger's Avatar
I am not going to quote the IRC paragraph but from experience I can quote that nothing flammable as in vapor or toxic is allowed within a return or supply and I have found them all. Waste drains, Flue vents, gas lines
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 1/8/09, 5:31 PM
Alarm installers love to run their lines in returns! Even seen their loudspeakers in them.
Abraham Lincoln
Old 1/8/09, 7:45 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you want true surround sound, it is the only way
Old 1/8/09, 9:42 PM
Marcel Gratton's Avatar
Rule 2-126 of the C.E.C., Part 1 permit type NMD90 cable to be installed in joist and stud spaces (i.e., cold air returns) in dwellings. It is recommended that type NMD90 pass through such spaces only if they run perpendicular to the long dimensions of such spaces.
I am not aware of any restrictions with regards to waste/vent and water supply piping inside returns.
On The Level Inspection
Gatineau, Québec
Old 1/8/09, 10:09 PM
Darren St.jacques's Avatar
Darren St.jacques Darren St.jacques is offline
Hi John,
In my opinion, it is bad practice to run anything through the returns.
The builder may be doing it because it was accepted practice from days gone by.
Having said that, it is still being accepted by building inspectors that if there are no other means to route wiring.
If you have one, check the building code book for it. I have an OBC and will check for you if you like. Any plumbing will promote moisture from condensation and as Darrell stated, if wiring, the penetration needs to be protected with a plastic bushing or grommet.
Old 1/8/09, 10:39 PM
Originally Posted by dstjacques View Post
Hi John,
Thanks Darren and others. It looks like, at least in Canada, you can run pretty much anything you like through the cold air returns and not be violating any codes.
Old 1/12/09, 12:51 AM
Heck, I think I have a mouse that keeps running through mine!
Out come the traps
Old 1/12/09, 10:41 AM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
" COLD AIR RETURNS"
I thought it was a weather report ! It is going to be -25*C here tomorrow night and lower later in the week! I guess that is why I assumed the weather report thing!
Hot water first then cold out of cold side of fixture jberthiaume Plumbing Inspections 19 3/12/08 2:32 AM
Returns location rdawes Inspecting HVAC Systems 10 10/9/07 1:21 PM
TPR Valve on Cold water pipe lewens Plumbing Inspections 11 3/5/07 5:53 PM
cold climates: insulating floors w/plumbing above cold crawlspaces kshepard Plumbing Inspections 6 9/26/06 12:09 AM
