Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 1/9/07, 11:32 AM
Roy D. Cooke, Sr's Avatar
Default complaints against home inspectors.
Buyer beware before closing home purchase
Tuesday, January 09, 2007
Dear Barry,
I've got two general complaints against home inspectors. The last two inspectors I hired inspected the roofs from the ground only, and neither reported any defects. That's problem number one. I have also found that home inspectors won't admit to errors made during their inspections. When problems are discovered after the purchase, they often dismiss them as "normal conditions." For example, when I found that my main water-shutoff valve was leaking, I called my home inspector, and he said that was normal. How would you rate this kind of performance? --Gary
Dear Gary,
Some home inspectors are definitely more professional than others, and your inspectors have apparently been on the lower end of that spectrum. All home inspectors miss a random sampling of property defects. That's the human aspect of doing business. But when errors and omissions are discovered, inspectors should respond in a forthright manner, rather than making excuses. That is the honest and acceptable standard in any business.
Inspecting a roof from the ground is little better than not inspecting it at all. Walking the roof, or at least inspecting it from atop a ladder, is essential to performing an adequate evaluation. The only acceptable excuse for not walking on a roof is inaccessibility due to steepness, height, roof type, or weather conditions. When a roof-walk is not possible or is deemed unsafe -- when it might cause damage to the roofing material or to the inspector -- a ladder provides the second-best perspective. By placing it against the eaves, at various positions around the building, most roof surfaces can be reasonably viewed. If eaves are too high to accommodate a ladder, high-powered binoculars provide the only means of adequate roof inspection from the ground.
Common roof defects of all kinds can go entirely unnoticed when viewed from the ground. Examples of unapparent roof problems include weathered and worn shingles, cracked tiles, displaced tiles and shingles, rusted flashing, packed gutters, and much more. This is a matter of common knowledge among home inspectors, leaving no plausible excuse for those who perform ground-view roof inspections. Home inspectors who compromise the quality of their work in this way should clarify this in their reports by stating that the roof inspection was limited in scope and that further evaluation of roofing conditions is recommended before the property purchase is completed.
Dear Barry,
Our house is about 15 years old and has a brick fireplace. Whenever it rains hard and long, the bricks get wet and water sometimes drips into the firebox. How should we address this problem? --Jackie
Dear Jackie,
The solution to fireplace leakage depends upon the specific cause of the problem. It there is no chimney cap, the solution may be simple: Have an approved cap installed by a qualified fireplace specialist. If there is a design flaw in the fireplace construction, evaluation by a qualified expert is necessary to determine what repairs are needed. This can be done by a licensed masonry contractor or other fireplace specialist.
To write to Barry Stone, please visit him on the Web at www.housedetective.com.
Barry now does not mention any association. Roy Cooke
Old 1/9/07, 2:09 PM
phinsperger's Avatar
Default Re: complaints against home inspectors.
Yes, And all doctors mis a random sampling of medical conditions. Imperfect beings living in a imperfect world. Better inspectors will hopefully miss less and not miss at all the ones that matter.
That response to the second one (Jackie) sure sounds a lot like a narrative you'd find in a report from a home inspector.
Old 1/9/07, 2:49 PM
Vern Mitchinson, CMI's Avatar
Vern Mitchinson, CMI Vern Mitchinson, CMI is offline
2. Standards of Practice
2.1. Roof
I. The inspector shall inspect from ground level or eaves:
A. The roof covering.
B. The gutters.
C. The downspouts.
D. The vents, flashings, skylights, chimney and other roof penetrations.
E. The general structure of the roof from the readily accessible panels, doors or stairs.
II. The inspector is not required to:
A. Walk on any roof surface.
B. Predict the service life expectancy.
C. Inspect underground downspout diverter drainage pipes.
D. Remove snow, ice, debris or other conditions that prohibit the observation of the roof surfaces.
E. Inspect antennae, lightning arresters, or similar attachments.
Old 1/9/07, 2:54 PM
rwand1 rwand1 is offline
Barry is no home inspector and certainly not a lawyer. Very disappointed with his advice of late. So much so I don't even read his column unless someone posts it here.
Barry get a grip on reality! You have been out of the trench too long!
Buckeye Home Inspections Service Area sboyd2 Miscellaneous Discussion for Inspectors 3 9/4/06 8:21 PM
New Hampshire Real Estate Agents Are Upset! fcarrio General Inspection Discussion 8 2/11/06 2:35 PM
