Go Back   InterNACHI Message Board > Geographically Specific Forums > Canadian Inspectors
Canadian Inspectors This forum is specifically for Canadian Home Inspectors.
Old 9/9/07, 2:39 PM
Default What is a 'condenser' dryer ??
I have a daughter who is in Germany (my son-in-law is in the Canadian Air Force) for a few more years.
She was talking about her Clothes dryer .
I though others would be interested in how they work ,
They are 50 Cycle in Europe.
.......... Cookie
http://ths.gardenweb.com/faq/lists/laundry/2004120958010854.html
A condenser clothes dryer is a machine that looks just like a conventional tumble clothes dryer, but which does not require an external vent. For the user/owner, operation of both types of dryers is essentially the same - the difference is in the internal design.
In a vented clothes dryer, air is drawn from the surrounding area (i.e. the laundry room), then heated and blown through the clothes as the drum tumbles them about. This hot air evaporates some of the water in the damp fabrics, and the resultant moisture-laden air is then exhausted through a vent duct to the outside.
In a condenser dryer, there are two separate "loops". The inside "loop" of air is sealed from the outside environment - air from within the drum is heated, then blown through the tumbling clothes, then the moisture-laden air is passed through a heat exchanger, where the water recondenses. The same dry air is then reheated, where it is again blown through the drum and clothes, and the cycle begins again (this is a more-or-less continuous process).
The outside "loop" in a condenser dryer consists of either air or water. Some condenser dryer models are air-cooled, and use the ambient room air as a heat sink, by blowing it across the outside of the heat exchanger. These dryers will tend to heat the indoor air in one's laundry room significantly. Note however that ONLY heat is released - all MOISTURE is contained within the unit. The condensed water can be either pumped away to a drain line (e.g. into a standpipe shared with the clothes washer) or stored in a container within the dryer to be emptied later (not all models offer both options). All standalone Euro condenser dryers are of this type, i.e. units from Miele, AEG, Bosch, Asko, Malber, and Eurotech.
In "combo washer/dryers" (i.e. machines that can BOTH wash and dry the clothes), the ventless condenser system is also widely used, but in these cases the condensers are water-cooled. During a dry cycle, several gallons of cold water are used to condense the moisture evaporated from the clothes, which again is pumped away through the drain line. Most of the "combos" currently available in North America use this method - i.e. units from Equator, Splendide, Malber, Haier, Quietline, Thor, LG, and Eurotech. Note that unlike the air-cooled design, these models do NOT significantly heat the indoor air in one's laundry room - but on the other hand, the fact that they use extra water during the dry cycle must be taken into consideration, especially for anyone on a very limited (or expensive) water supply.
Since air-cooled condenser dryers heat the indoor air, they're most suited for use in cold to moderate climates (it would be counterproductive to run what amounts to a space heater at the same time you're trying to cool the house with air conditioning). However, condenser dryers do have one big advantage - they don't exhaust any air to the outside. And hence, on very hot days, a condenser dryer may surprisingly be as good or even better than a vented dryer in overall energy terms - it heats the indoor air, but on the other hand it doesn't exhaust 200+ cubic feet of nicely HVAC-cooled indoor air to the outside per minute of operation!
All else being equal (i.e. not including household heating/cooling issues), condenser dryers are slightly less efficient than their vented counterparts, typically on the order of ~15%. The real design intent of condenser dryers isn't improved efficiency, but the simple fact that they don't require a vent duct, permitting easy installation most anywhere (ideal for apartment dwellers, etc).
With most current standalone condenser dryers, it is necessary to periodically clean the condenser unit - perhaps once a month or so, one needs to slide out the condenser module and wash off any accumulated lint. Thus condensers require a bit more "work" than vented dryers - although this may entail less actual effort than the recommended annual ductwork cleaning for vented dryers (which is very important for both performance and fire safety reasons!).
Overall, if you have a very short run to the outside (e.g. your laundry room is located adjacent to an exterior wall, with a proper vent duct in place), it probably makes more sense to stick with a conventional vented dryer. But if you have a very long vent run (which will likely result in excessive drying times and inefficient operation, as well as being difficult to clean), a condenser dryer is a good option. Unfortunately, at the time of this writing, only compact-size Euro condenser dryers are available in North America...
Of course, these comparisons are based on electric dryers - if you have a proper vent duct, gas dryers are almost always going to be much less expensive to operate than any sort of electric dryer, simply because gas is generally cheaper than electricity for the consumer.
Finally, it should be pointed out that virtually all condenser dryers use simple heat exchangers as described above - NOT dehumidifier-style compressor-based heat pumps. Thus they're not overly complex, and are about as reliable as vented dryers - but not any more efficient either. There IS in fact a true heat pump dryer - the AEG Lavatherm WP - which is very energy-efficient, but it's not available in North America, and is extremely expensive (probably so much so that it wouldn't pay for itself in energy terms).
Roy Cooke.RHI.
http://royshomeinspection.com/
Questions 613-475-1144
Roycooke@sympatico.ca
" A life spent making mistakes is not only more honorable but more useful
than a life spent doing nothing." George Bernard Shaw
Old 9/9/07, 3:13 PM
Default Re: What is a 'condenser' dryer ??
Good information Roy, did not know of such a dryer.
Sounds like the thing to use in colder climates, but does it come in 60 cycle?
Thanks.
http://www.themainehomeinspector.com/
Serving all of Kennebec County and Central Maine
Cyr Home and Commercial Property Inspections
IAC2 Certified
http://co.nachi.org/inachiawards
Inachi 2009 US Member of the Year
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
Old 9/9/07, 3:28 PM
phinsperger's Avatar
I'm not real clear if that also takes into account the air changes required for vented dryers? It kind of sounds like like it does but it doesn't seem to clearly state so.
Old 9/9/07, 4:06 PM
I tell all mt clients to improve your Dryer Cost, summer and winter to open the window ( if there is one ) near the dryer as the dryer changes all the air in the Home ( average home ) once every hour of its running so you loose a house full of heat in the winter and a house full of cooling in the winter Per hour.
Those who do not vent either have a loose home ar are looking to grow mould.
No not available in 60 cycle so that they would need a motor change .
I told her for our area to just buy a New dryer when she comes home.
.. Cookie
Roy Cooke.RHI.
Old 9/9/07, 4:20 PM
rwand1 rwand1 is offline
Dehumidifier.
Old 9/9/07, 4:27 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
I just had one of those newer units a couple of months ago.
I recommended to watch the filter.
Back to the BEARS
Old 9/9/07, 4:43 PM
What about Microwave Clothes Dryers
  • Just as microwave ovens dramatically changed the way many people cook or re-heat food, microwave clothes dryers may change the way people dry clothes after they are washed (or after they come in from the rain!). With a microwave clothes dryer, the microwave instantly heats the clothes, leading to quicker drying times. However, clothing with metal parts (such as zippers and metallic buttons) would not be suitable for this product.
  • Current research is involved in creating a "secondary" dryer, much like the microwave oven is a "secondary" oven used for small amounts of food.
Old 9/9/07, 5:00 PM
  • Some Web sites that discuss the research and products are shown below:
Sounds like a good idea Paul, but I don't think your link works.
[IMG]res://C:\WINNT\system32\shdoclc.dll/pagerror.gif[/IMG]The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.Please try the following:
HTTP 404 - File not found
Internet Explorer
<H1>File Not Found</H1>We’re sorry, but there is no Dairynet.com Web page that matches your entry. It is possible you typed the address incorrectly, or the page may no longer exist. You may wish to try another entry or use our keyword search above, which we hope will help you find what you’re looking for.
Marcel
IAC2 Certified
Shingle Technology
Old 9/9/07, 6:33 PM
Sorry,
Try this one;
http://www.appliancemagazine.com/edi...zone=1&first=1
Old 9/9/07, 7:02 PM
Paul, for a minute, I thought the Author would be Einstein. ha. ha.
Thanks. Interesting information.
Marcel
</IMG></IMG>
IAC2 Certified
Shingle Technology
Dryer sheets potential hazard badair Misc. Discussion 8 11/26/07 10:19 AM
Testing a dryer outlet acox Electrical 14 7/27/06 10:51 PM
Dryer lint filter senomoto Misc. Discussion 6 5/14/06 10:01 AM
Bad Dryer and Bath Fan Venting Jkrt00 HVAC 3 3/13/06 11:07 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
