| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi
i have a question about crawlspace ventilation... in the course i took last year, the ratio for crawlspace ventilation was 1:300 , but in the NACHI course it's 1:150.. can anyone pls direct me in the right direction? thx |
| Need a home inspection in Saskatchewan? Check out InterNACHI's listing of Saskatchewan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Check with your local AHJ/code. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Even if it has a VB, I look for a lot of vents or note the potential for high moisture content in the wood.
Local conditions prevail.
Here's an example from OBC - Ontario Building Code (2) Where an unheated crawl space is ventilated by natural means, ventilation shall be provided to the outside air by not less than 0.1 m² of unobstructed vent area for every 50 m² of floor area. (3) Vents shall be, (a) uniformly distributed on opposite sides of the building, and (b) designed to prevent the entry of snow, rain and insects. 9.18.3.2. Ventilation of Heated Crawl Spaces (1) Heated crawl spaces shall be ventilated in accordance with Section 9.32.Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
I advise my clients not to ventilate the crawlspace.
Who would want humid air condensing on the cold floor / walls. Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Great infos guys!!
thx! |
Here is some Info more if you need it http://www.hgtvpro.com/hpro/bp_found...463221,00.html http://www.buildingscience.com/docum...ce-insulation/ Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thx Roy!! very helpful links indeed! |
Glad to help any questions any time do not hesitate ..
Although we can see there is some mixed opinion here, several points need clarification.
1. Is it a "heated" crawlspace versus "unheated"? 2. What would the building "standard" be at the time of construction? My point being does an engineers "opinion" trump "building code" as may be suggested; or perhaps be careful of how the inspector reports an opinion beyond the standards of practice. Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
Claude how about you give us your thoughts and answer your own questions .. Roy
I have seen too many damp from ventilation full of mould CS and cold rooms will give my thoughts and ideas to my client how to help have a healthier home . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Patrick posted the question. I simply reponded attempting to indicate what the code states in Canada, offering help.
Seems you take exception to my response - that is unfortunate! How would I know if Patrick's question is related to a heated or unheated crawlspace? My point was simply there may be other "conditions" that equally make crawlspaces not as damp. This includes proper/adequate ventilation. It goes back to simple logic of the intent of building code, and considering the conditions encountered by the inspector. Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
NO Claude I did not take exception to your post sorry if it came across that way .
("Seems you take exception to my response - that is unfortunate ") . I and others are always looking on how to educate our selves and others . If you have some information or thoughts I was just asking you to share them . For you to not give facts or ideas is unfortunate for all. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I omitted to say that I also recommend that the perimeter walls be insulated, a sealed VB on ground and perimeter walls be installed and a source of heat provided being we are from the great white north. Cheers, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
ok here is the situation :
surface : 30 feet x 24 feet floor : dirt (irregular 2 to 8 feet of clearence) VB : covers only half of the ground surface Ventilation : 2 (on opposite walls) size 2 inches X 2 inches Heat : one big a** electric heather (220) takes alot of energy to run moisute : alot insulation between joists (floor) : missing half of it insulation on walls : none Fix : -insulate between joists -VB everywhere (min 6 inch over laped...taped ) -insulate walls (fiberglass boards or spray foam + fire retardant) -get rid of the big a** heater -block the ventilation holes -can't really add gravel over the VB because of the irregular ground -insulation tubing over the copper pipes i"m i on the right track? i would think yes , but if i"m missing something pls add it up!! lolll thx Last edited by pmassie; 2/27/10 at 11:00 AM.. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Crawl Space Ventilation | rfrost | Interior Inspections | 2 | 5/16/09 7:54 AM |
| Way More Intake To Supplement Minimal Exhaust Ventilation? | Ed Fako | Exterior Inspections | 1 | 12/19/08 6:07 PM |
