Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 1/14/08, 2:30 PM
Charles Bono Charles Bono is offline
Default disimilar metals
Did an inspection of new home recently and found that the ground clamp attached to the incomming copper water supply pipe is made of metal and knowing that disimilar metals corrode over time, is it required to be called out?
I have called this out in other homes but it seems that all/most electricians use them. Surely they would know that disimilar metals corrode.
Thanks for the help.
Charles
Old 1/14/08, 4:14 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: disimilar metals
Good point tho I would think that is not as serious as two supply line pipes having disimilar metals.
After all it is a lovely shade of green
Old 1/14/08, 4:49 PM
rwand1 rwand1 is offline
Personally I would not make an issue of it. I see white type metal clamps all the time on copper incoming water lines. Can't say as I have ever seen one causing a problem and I have been inspecting since 1991!
Old 1/14/08, 4:59 PM
Ray
thanks for your advice.
Charles
Old 1/14/08, 6:13 PM
as an additional note, in newer construction where the cold water line is bonded to the steel gas pipe leading at hot water heater all those clamps are the white metal variety, for what its worth.
Old 1/14/08, 9:47 PM
http://www.arrisistore.com/subcat.php?cat=NGD
Old 1/14/08, 10:06 PM
jkogel jkogel is offline
I'll bet there's a non-corrosive plating of some kind on those clamps, or an alloy rather than plain mild steel.
I'm posting a picture of a brass clamp on a galvanized steel ground rod with a rather tarnished copper grounding conductor, installed around 1965. I called for a repair here, but the worst corrosion is where the conductor is in contact with the dirt.
Old 1/14/08, 10:08 PM
On the link above it said some clamps are zinc or zinc coated?
Old 1/14/08, 11:48 PM
That is an interesting point, Raymond. On an outboard or a boat hull, the sacrificial Zinc is bolted to the leg or the hull because with electrolysis, especially in salt water, it corrodes faster than any of the other metal components. So the clamp will rust before the coper pipe.
Old 1/15/08, 12:27 AM
Yuri Olhovsky's Avatar
Yuri Olhovsky Yuri Olhovsky is offline
Corrosion can impede the quality of the ground. I don't make an issue out of it but I always recommend my clients to replace it. This is the same thing as copper hangers or copper nails used to support the copper pipe. If the pipe will be supported with galvanized hangers, I think everybody will call it out. Builders know that corrosion will occur there but it will take years. Bottom line is they can put clamp for about half price ($2 versus $4) and save some money </IMG>
Yuri Olhovsky CMI, CEA, PHPI, RASDT
National Home Inspector NHICC #00372
Richmond Hill, ON Canada
NACHI ID 04070207
Old 1/15/08, 8:41 AM
phinsperger's Avatar
The Galvanic Table
Active (Anodic) (+)
  1. Magnesium
  2. Mg Alloy AZ-31B
  3. Mg alloy HK-31A
  4. Zinc (hot-dip, die cast, or plated)
  5. Beryllium (hot pressed)
  6. Al 7072 clad on 7075
  7. Al 2014-T3
  8. Al 1160-H14
  9. Al 7079-T6
  10. Cadmium (plated)
  11. Uranium
  12. Al 218 (die cast)
  13. Al 5052-0
  14. Al 5052-H12
  15. Al 5456-0, H353
  16. Al 5052-H32
  17. Al 1100-0
  18. Al 3003-H25
  19. Al 6061-T6
  20. Al A360 (die cast)
  21. Al 7075-T6
  22. Al 6061-0
  23. Indium
  24. Al 2014-0
  25. Al 2024-T4
  26. Al 5052-H16
  27. Tin (plated)
  28. Stainless steel 430 (active)
  29. Lead
  30. Steel 1010
  31. Iron (cast)
  32. Stainless steel 410 (active)
  33. Copper (plated, cast, or wrought)
  34. Nickel (plated)
  35. Chromium (Plated)
  36. Tantalum
  37. AM350 (active)
  38. Stainless steel 310 (active)
  39. Stainless steel 301 (active)
  40. Stainless steel 304 (active)
  41. Stainless steel 430 (active)
  42. Stainless steel 410 (active)
  43. Stainless steel 17-7PH (active)
  44. Tungsten
  45. Niobium (columbium) 1% Zr
  46. Brass, Yellow, 268
  47. Uranium 8% Mo
  48. Brass, Naval, 464
  49. Yellow Brass
  50. Muntz Metal 280
  51. Brass (plated)
  52. Nickel-silver (18% Ni)
  53. Stainless steel 316L (active)
  54. Bronze 220
  55. Copper 110
  56. Red Brass
  57. Stainless steel 347 (active)
  58. Molybdenum, Commercial pure
  59. Copper-nickel 715
  60. Admiralty brass
  61. Stainless steel 202 (active)
  62. Bronze, Phosphor 534 (B-1)
  63. Monel 400
  64. Stainless steel 201 (active)
  65. Carpenter 20 (active)
  66. Stainless steel 321 (active)
  67. Stainless steel 316 (active)
  68. Stainless steel 309 (active)
  69. Stainless steel 17-7PH (passive)
  70. Silicone Bronze 655
  71. Stainless steel 304 (passive)
  72. Stainless steel 301 (passive)
  73. Stainless steel 321 (passive)
  74. Stainless steel 201 (passive)
  75. Stainless steel 286 (passive)
  76. Stainless steel 316L (passive)
  77. AM355 (active)
  78. Stainless steel 202 (passive)
  79. Carpenter 20 (passive)
  80. AM355 (passive)
  81. A286 (passive)
  82. Titanium 5A1, 2.5 Sn
  83. Titanium 13V, 11Cr, 3Al (annealed)
  84. Titanium 6Al, 4V (solution treated and aged)
  85. Titanium 6Al, 4V (anneal)
  86. Titanium 8Mn
  87. Titanium 13V, 11Cr 3Al (solution heat treated and aged)
  88. Titanium 75A
  89. AM350 (passive)
  90. Silver
  91. Gold
  92. Graphite
End - Noble (Less Active, Cathodic) (-)
Old 1/15/08, 8:43 AM
Fwiw
I have seen more lose clamps on the pipe and loose set screws on grounding clamps and bonding clamps. To me that is more of an immediate concern. Usually I just tighten the clamp.
Copper is a Noble metal.
http://en.wikipedia.org/wiki/Noble_metal
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Two differant Metals? gbrasseur Plumbing Inspections 3 11/16/06 3:17 AM
