Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/10/06, 8:05 PM
rwand1 rwand1 is offline
Default Double Taps
I had a realtor tell me today that electricians are getting peeved at home inspectors for calling out double taps. Yet in the home that was inspected there were three double taps, with room for more breakers. I called it out and suggested the vendor repair prior to closing of title. The building permit was okay, and there was a ESA orange sticker on the panel, but no dates or anyother mark on it.
So what is the story, I like to think those electricians are wrong, because double taps lead to nuisance trips because you have doubled the load?
If the building permit is signed off, and the panel was done by an electrician is it right? I know the electricians are left to their good discretion, but I also know ESA inspectors only inspect a representitive number of new homes, not all of them, they entrust the electrican?
Confused.
Old 3/10/06, 8:43 PM
phinsperger's Avatar
Default Re: Double Taps
I write them up also. I also inform the client about how common (I didn't say correct) it is.
Old 3/10/06, 9:14 PM
This seemed like a good explanation that I pulled from somewhere:
Double tapping and lugging can create hot spots on breakers and neutral bars if not tightened to the correct torque and especially if two different size conductors are used. Because the hot and neutral wires are current carrying conductors, the chance is then greater for potential hot spots. If the double tap or lug becomes lose, it begins to arc. As it arcs it builds up carbon. Carbon is then resistance and with the more carbon buildup the more difficult it is for the conductor to make contact....thus increasing the current. End result can be the breaker tripping because of the loose conection (excessive current exceeding the rating of the breaker), or signs of overheating such as discolored wires, melted wires, etc, or worse yet...fire!
110.14(A)..."Terminals for more than one conductor and terminals used to connect aluminum shall be so identified."
Old 3/10/06, 9:58 PM
Roy D. Cooke, Sr's Avatar
Confused.
I would expect the ESA sticker was put there by the electrictian who did the job. They now only inspect a very small amount of the homes that are wired by an established contractor. It might be a simple thing for the purchaser to call the original contractor and state that a home inspector said that double taps are not allowed in most cases ( SQ D is one ) and that they are wondering if they should call the local hydro authority. I expect the original contractor will fix it for free as he does not want ESA to know he scewed up .
Roy Cooke .... RHI........... Cahpi-on
A HAPPY NACHI member.
Old 3/11/06, 1:15 AM
Brian E. Kelly's Avatar
Many Square panels allow two same size conductors.
Old 3/11/06, 7:14 AM
twheeler
Guest
Posts: n/a
But only if the load is not maxed out
I always make note of the fact that there is double tapped circuits, and make recommendation that the electrical panel be inspected by a licensed electrician.
Old 3/11/06, 8:01 AM
It does say "and"...relating to double tapping/lugging hot spots but you're correct many Sq. D breakers allow two same size conductors.
Old 3/11/06, 8:39 AM
Thanks guys. I will be contacting ESA this week and see if I can get a policy statement from them in regards to double taps.
Unfortunately it is the realtors who have to take the word of a licenced electrician over that of a home inspector. Still don't understand how a Square D double tap can be any different from any other double tapped breaker as it is still possible to double the load, thus resulting in tripping.
Thanks again.
Old 3/11/06, 8:47 AM
Raymond, If they provide you with a statement please post it for all to see.
Old 3/11/06, 8:51 AM
To quote Roy Cooke Sr., "you bet ya!"
Old 3/11/06, 10:32 AM
Most breakers aren't made for two wires like this Sq. D pic:
I can go by what I see such as whether the manufacturer allows 2 wire on a breaker but I don't do load calculations for the 2 wire loads.
Old 3/11/06, 10:41 AM
jwortham jwortham is offline
Please Note: jwortham is a non-member guest and is in no way affiliated with InterNACHI or its members.
I call out the double-taps.
If the electrician then says they are fine, and signs off on them, not my concern. I've done my job advising my client.
I don't tell a realtor how to sell a house. They don't get to tell me how to inspect one.
Old 3/11/06, 3:44 PM
Nice picture Larry, many times you can read the wiring diagram in the panel showing whether two conductors are allowed or not. I believe if they are allowed than it is not a double tap.
Old 3/11/06, 4:23 PM
Same here, Brian. I don't care to pay for the electricians trip out for no reason.
Old 3/11/06, 9:02 PM
Vern Mitchinson, CMI's Avatar
Vern Mitchinson, CMI Vern Mitchinson, CMI is offline
Rule 6-212 & 12-3034 Says "It is not correct to connect two or more wires to a circuit breaker or fuse."
From 7th edition of Alberta Book 1, Electrical code simplified (residential wiring)
Based on the 18th edition of the Canadian electrical code and Alberta amendments.
This code was printed in 1999. It may have changed in later editions.
I drought it. If anyone has a later edition that says something different I would like to hear it.
Anytime I see a double tap I flag it for a licensed electrician the repair.
Vern Mitchinson_CET_CMI
Past President
International Association of Certified Home Inspectors. Alberta Canada
Double Tap Questions jkogel Electrical Inspections 6 6/28/07 10:46 PM
Square D double taps abishop Electrical Inspections 3 10/29/06 10:01 AM
Double Taps... Here we go again rwand1 Canadian Inspectors 4 10/28/06 4:55 PM
Double taps Mike Parks Electrical Inspections 11 5/28/06 2:52 PM
Double Taps psmothers Electrical Inspections 3 3/9/06 11:04 PM
