Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 10/29/06, 12:36 AM
kbroad kbroad is offline
Default Electrical Puzzle!
I'd appreciate your opinions on this situation:
While looking at a 42 circuit electric panel rated for 200 amps, with the deadfront off, my left hand was touching the left side of the panel box as I moved aside an ungrounded conductor (a black wire) with my right hand to better view some connections of the grounding wires. I got a pretty good zap! The black plastic insulation did not appear cracked or damaged in any way and I was nowhere near the stripped end. I was standing on a dry lino-covered wood floor over a crawlspace. I used a volt meter between the body of the panel and a separate independant ground to see if the panel body was energized and it was not.
So why did I get zapped??
Thanks for your thoughts!
Keith
Keith F. Broad
Broad Spectrum Inspections
www.broadspectruminspections.com
Old 10/29/06, 12:53 AM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Default Re: Electrical Puzzle!
Can't think of any reason you got zapped...but two things kinda jump out here. One- you shouldn't be sticking those bare little pinkies in there in the first place, naughty naughty. Two - definitely don't ground yourself to the panel while doing it If you must move live wiring at least use some type of non-conductive plastic insulated device.
</IMG>
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 10/29/06, 1:37 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Even though the wires are insulated there is a enough electrical magnetic force in the box that if you ground yourself to the panel you become the conductor. 1. you ever use a volt probe and even before you get to the live wire it lights up or beeps thats electricity in the air. 2. Thats why your supposed to use electricians gloves so if you accidentally ground yourself you don't kill yourself.
My friend you don't know how lucky you were.
Gerry
Old 10/29/06, 7:29 AM
rwand1 rwand1 is offline
Were your hands moist? The insulative jacket could have a hairline crack?
Old 10/29/06, 7:40 AM
Roy D. Cooke, Sr's Avatar
Keith
Big Tip ....use left hand to turn all switches of and on.
If something goes bad flash passes your left side not in your face .
Put one hand in pocket then if you are carless enough to get into a hot wire the current does not go through the heart less apt to die that way .
Not Jokeing had two disconects explode I heard bells in the head for a few days but no lasting damage .
Old 10/29/06, 7:49 AM
How can you use one hand to hold the panel and turn the screws. You need both hands?
Old 10/29/06, 7:53 AM
Thats the beauty of the cover you can not get your fingers in where they should not be .
I give You Raymond permission to now use two hands .
Enjoy Roy
Old 10/29/06, 2:13 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Are you sure there was no permanent damage?
Just joking!
Old 10/29/06, 2:25 PM
Just joking!
Excuse me I have to answer the phone ,17 times today and they always hang up when I answer.
I know I am a sicky tooooo
Roy Cooke
Old 10/29/06, 2:43 PM
I have had some minor mishaps with electrical panels.
1. Putting screw back into panel cover the screw hit a live wire. (Pointed screw)
2. Putting screw back on panel and receiving shock from panel.
3. Client in bare feet leans on basement refrigerator and gets zapped.
4. Putting panel cover back on and hitting something live and causing sparks, no shock.
This is over a sixteen year span.
Old 10/29/06, 2:54 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Putting a pointed cover screw back into a panel.
Do you still do that???
Old 10/29/06, 3:08 PM
What amazes me is that no rocket scientist at the factory that makes these electrical panels, has thought of bending that little bump of metal to the exterior so the screws go through to the outside of the panel?:shocked:
Wouldn't take much would it...
Darrell Hadler CMI
Old 10/29/06, 3:13 PM
phinsperger's Avatar
I've also wondered why they don't bend it to the outside. I suppose its because if the correct screw was used there shouldn't be a problem.
Old 10/29/06, 3:16 PM
More than likely they discovered the mistake afterwards and would cost to much to retool.
Gerry
Old 10/29/06, 3:20 PM
Erby
I was waiting for someone to ask that question.
Yes I put the screw back in because that is the way I found the panel. The rest of the screws were all inappropriate too. I reported the problem in the report, and I told the agent, and I left the breaker off and marked it for the electrcian, and put the panel cover back on.
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 1:14 PM
Chicagoland Electrical Code Ordinance jtedesco1 Electrical Inspections 0 6/16/06 2:10 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
