Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 8/29/06, 6:50 AM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
Default Furnace Age
Could anyone tell me the age of a furnace made by Grimsby, Model # 100/117 and Serial Number 930500355, Series S709 and No- 15621, the CD book says a letter and followed by a # should be on the label, but could not find it?? thanx
Chuck Crooker/CROOKERHANCOX HOME INSPECTIONS INC. Brantford , Ontario www.crookerhancox.com "Not just an inspection, an Education!!!"
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 8/29/06, 7:13 AM
Rob A. Parker Rob A. Parker is offline
Send a message via ICQ to rparker
Default Re: Furnace Age
Chuck is it areal old unit .I see you have a series # s7090 that could be the age also.
Rob Parker RHI CMI
ITC Level 1 Thermographer
Thamespec Inc.
www.thamespec-inspections.com
Old 8/30/06, 10:10 PM
Originally Posted by rparker
Chuck is it areal old unit .I see you have a series # s709 that could be the age also.
Hi Rob, the furnace looks in real good shape and not rust, I am thinking 15 +/- yrs. old
Old 8/31/06, 7:24 AM
Well if it looks in good shape how about the serial mumber first 2 the year next two the month.I find in general the first 4 numbers work more times than any thing ells on most furances I have looked at.You can also look for a gas tage on the gas line the gas techs are required to put a tage on the line every time they change something.I have found that in a lot of cases the age of the furnace matches the date on the gas tage.
Rob Parker RHI CMI
Thamespec Inc.
Old 8/31/06, 7:37 AM
No tags, hence the suggested age of 15+-.
Old 8/31/06, 4:17 PM
Chuck I think you are right,first two mumbers are 93 could only be 13 years old but 15+/- will work.
Rob Parker RHI CMI
Thamespec Inc.
Old 8/31/06, 9:41 PM
dplummer dplummer is offline
Please Note: dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'd guess May 1993. Doug
Old 9/1/06, 7:16 AM
rwand1 rwand1 is offline
Did you check the blower housing for a date stamp?
Old 9/1/06, 7:19 AM
That would be my guess too Doug ,could possible be made by carrier that how thier serial numbers work first 4 numbers date it was made.
Rob Parker RHI CMI
Thamespec Inc.
Old 9/1/06, 8:50 AM
Rob, just got back from a home with almost the same, the Serial # was 934502594 and the model #is 100/117 and the home was built 12-13 years ago. So I am thinking that the ser. # may be a good hint for the age. Even though the CD book says that a date is on the label but no can find it on either furnace.
Old 9/1/06, 9:00 AM
In my opinion the CD book is not all that useful.
Old 9/1/06, 1:34 PM
Chuck I had a new furnace installed about 2 years ago it's a Goodman which is made by or owns Carrier the serial # read the same.First 4 number are date of manufacture.
Rob Parker RHI CMI
Thamespec Inc.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 28 10/21/07 6:26 PM
Furnace Not Responding vsantos Inspecting HVAC Systems 4 9/18/07 8:00 PM
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 2:56 PM
Armstrong Ultra 80 Oil Forced air furnace Stephen Frazer Inspecting HVAC Systems 19 4/9/07 8:00 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
