Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 10/16/07, 9:41 AM
gmortensen gmortensen is offline
Please Note: gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Garage finishing
In Ontario, the walls in the interior of a garage, do they have to be fire rated, form an air barrier, to prevent gas from entering the house?
Old 10/16/07, 10:12 AM
mdiplock's Avatar
mdiplock mdiplock is offline
Default Re: Garage finishing
All walls and ceilings that are separating garages from the home must be gas tight in Canada and fire rated in the U.S. If there is a man door going into the home it must have an automatic closing mechanism and be fire rated, minimum 45 minutes. They must also be insulated with a proper vapour barrier.
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself"
Regards,
Mark
Old 10/16/07, 10:17 AM
Banned
In Canada, we don't require that the wall be fire rated but that it be airtight with no holes through it so as to stop gas or fumes from entering the home. Any person door (no doors allowed from bedrooms to garage) from the house to the garage must have an auto-closing device installed and be airtight/ weatherstripped.
Old 10/16/07, 11:41 AM
Thanks guys.
Old 10/16/07, 12:48 PM
rwand1 rwand1 is offline
As to the fire rating check with your local municipality. I believe some jurisdictions may require the walls to have fire rating.
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 5:05 PM
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 12:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
Garage fire rated wall jlybolt Interior Inspections 3 6/18/06 6:21 PM
