| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
This is a 3 yr old Heil oil furnace with side wall venting and the vent looks like a liner. This is exposed and very hot and yes (my client touched it). Other than a safety hazard and the compromising of a whole whack of floor joists can anybody tell by my crappy pictures if this is proper venting for oil. I sure as heck don't like it but want to base my report on facts not my preferences.
| Need a home inspection in Ontario? Check out InterNACHI's listing of Ontario certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
To many things I do not like I would pass this on to qualified , Furnace ,and structer peole . No way I want to have my name saying this is Ok.
I am sure there are other things beside cut joices and drilled holes in Joices for me to be concirned on... Please keep us posted ... Roy Is that Black plastic I see for exhaust? Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thats part of my question Roy as I have not run across this setup before but I think the black is fan induced air to act as a suction right near the exit point. Do you think the other looks like liner material. Yes I told my client to call in an hvac tech to inspect and explain the install but NOT the same one that installed this mess.
cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is liner material, could be damaged easily and not noticed until everyone wakes up dead from carbon monoxide. I hope there is no ceramic tile above the joists. Since when did hvac guys start comprimising structure? It used to be only plumbers.
Fourth pic looks a litle close to level too for exhaust. Could be just the pic.
Would that type of direct vent system be ok to be level then Brian?
Kerr do recommend the 1/4"/foot upward slope that is typical of naturally vented-by-chimney systems but the through the wall system section is installed horizontally. Since the Kerr is a burner fan driven system, it really doesn't need the upward slope as does a naturally vented system...... it's airtight and the strong burner fan can blow the exhaust gases horizontally or even downward!! These direct vent systems are a new creature altogether!
Came across this on a 30 year old wood furnace on friday, could not tell if it was double wall. WETT certification coming up for it and main floor wood stove anyways, no liner in the clay flue etc.
The flex liner is not considered appropriate smoke pipe for a wood installation. Flue pipe shall be 26 ga for 6" diameter and under; 24 ga for 6" to 10" diameter; engineered over 10" diameter Hopefully the wood furnace and wood stove are on separate flues! |
Surprisingly had a ULC label, brass one, very tarnished but it was there. I advised the client that the furnace may not be insurable as per wett inspection. And if it was, not for long. I'm sure the flex pipe was a handyman idea. There was an oil fired boiler about 4 years old heating an addition with radiant and a coil in the forced air wood furnace. I recommended he finish the rest of the main floor with radiant.
Yes, the stove was on it's own insulated chimney. There was also a 200 amp main breaker in 150 amp panel, they figured they needed it when they ran a 40 amp service to the garage |
Were the boiler and furnace sharing the same flue? *PS- there are a strict set of clearances to combustibles for hot /return air plenums and ducting if not tested and stated on the unit.........may become another insurance issue. Last edited by Brian A. MacNeish; 11/21/10 at 9:38 PM.. |
Separate flues, boiler had a nice stainless insulated.
I think the wood furnace was being used as an air handler for the most part, it was in tact and wood stored in the basement so we have to assume it is being used for backup or to save on oil. Lots of little things, jet pump not hard wired, just plugged in. Vermiculite is being tested,some new window inserts with rot in the old brick mold and sills etc. |
From what I read Charles I would be concerned big time sounds to me like a rub goldbelg set up .
I would recommend further valuation on any of these serious concerns . And I expect there are many, impossible for me to do an inspection from a distance , and I think you seem to also feel there are many concerns. All the best ... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Room size requirement for HVAC supply | kweiss | Inspecting HVAC Systems | 3 | 6/9/07 6:58 PM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Commerical HVAC code question | sbyrnes | Inspecting HVAC Systems | 19 | 11/15/06 10:08 PM |
