| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
The serial # in that after the 9P(or whatever), the next two numbers are the series and the next two numbers are the Year. Unit's in the 1991 - 2001 yr. time frame have the recall, Please call 1-866-441-4645 and give them the #'s off the unit and they will send you the part.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Hi Chuck
The better Phone number to call, rather than the call centre, is Venmar directly at 1-800-567-3855 Patrick Young Complete Inspection Services Inc. Port Dover, Ontario 519-583-3502 |
I think we are entering unknown territory by trying to keep track of product recalls, let alone informing clients.
Is there concern amongst others about liability by mentioning recalls? I don't know about others but I don't keep track of all the recalls. The latest one that has come to light is Maytag front loading washers. And just this week flourscent light bulbs have become an issue. |
Interesting point Ray. If you start reporting product recalls are you not then implying that you are monitoring for all product recalls? And then if you miss one and there is a catastrophic fire, or the toilet tank cracks, or the garage door comes down on the new Bimmer or the built in vac' goes nuts and sucks all the fuzz off the Persian carpet and the pet cat or . . . . . . . .
Makes on wonder what CSA and Ulc, ESA are doing, let alone the manufactures testing procedures. I don't need the extra worry or the liability.
</IMG> Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
And if you don't know? If you start listing one recall then you have set a precedence of informing clients of recalls, and that would entail keeping an up-to-date recall list.
Personally I am not inspecting to take on that sort of liability and I don't believe your insurance policy requires it or would protect you from failure to mention items as its outside the scope of the SOP. |
Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
wjung is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chuck,
having been in this busness as long or maybe longer than Ray & Roy, I must agree with Ray's assessment on the recall issue. If you mention one you will have to monitor for all or you will sooner or later open yourself up to trouble and potential litigation. Our job is not to monitor recalls, it's the manufacturers and their distributors that should be informing consumers. Ray, Roy and myself have been through this discussion before over the past 20 years and had reached the same conclusion the last time this issue was raised. Be very, very carefull what you report on, because it might bite you in the back side at one point sooner or later. Best regards Wolf |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you point out Lennox Pulse furnaces if you come across one?? |
Good points Wolf about the manufacturers and distributors contacting the owners. Never thought of that.
Cheers, |
I guess I will take that as a yes, Raymond
No I leave it to the media and the press to relay recalls, they seem to be very good at doing that.
As to Lennox Pulse; which model year are your referring to? |
Jason,
to the best of recollection (however I could be wrong) the Lennox recall and free heat exchanger replacement program ended some time ago. If I remember correctly the furnaces affected were installed during a time frame in the 80's, which would mean most of them likely have been replaced since. I for one have not seen one in a very long time. Wolf |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Recall of Canadian Made VENMAR HRV | Nalliah Thayabharan | Inspecting HVAC Systems | 0 | 3/30/07 10:51 AM |
| Venmar Recalls for 1991-2001 | ccrooker | Inspecting HVAC Systems | 0 | 3/16/07 7:10 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
