| Canadian Inspectors This forum is specifically for Canadian Home Inspectors. |
rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
I just talked to my insurance agent had talked to the insurance Company and they charge a higher premium if you have a sprinkler system
in the home . They also will not cover water damage if the sprinkler goes on in a fire . They do give coverage for Knob and tube but charge a very high surcharge . They will not give insurance if the home has been a grow house Period. They will cover aluminum wiring if all receptacles and switches have been upgraded to CO/AL . Roy Cooke Sr |
Vern Mitchinson CET CMI Past President International Association of Certified Home Inspectors. Alberta
Roy Cooke sr. |
It seems that insurers can set their own rules, or change them from time to time as they see fit. As stated earlier I would have thought that the insurance should have been discounted because of the extra margin for fire safety. Such was common practice for commercial buildings.
So would they rather see minimized damage or a whole house possibly destroyed in a fire? Inspection Support Services Inc. "It is not the strongest of the species that survives nor the most intelligent, but the one most responsive to change." -Charles Darwin |
Fire sprinklers were never meant to reduce damage. There not even meant to to put fire out. The mearly cool the fire to slow it down long enough for people to get out. Thus they propect from loss of life not property damage
I have to think it is just Canada being behind some modern protection systems .
I will stay on top of this and see what more information I can gather . ![]() ![]() ![]() Sprinkler Systems Fire sprinkler systems aren’t just for apartment or office buildings anymore. Today any home can have one these high-tech, life-saving devices designed to extinguish fires in a flash. Home fire sprinkler systems, in fact, can contain and may even stop a fire in less time than it takes for the fire department to arrive. Here are some other important reasons why you should consider getting one. Some Surprising Facts
Plan Your Escape Even with home fire sprinklers, the same fire safety rules apply. When you hear a smoke alarm, get out fast. To increase your family’s chances of survival during a fire, be sure to:
Sooo, is the water and ax damage that the fire deptment cause covered?
I tell people if they have a fire the first thing you do is call the fire dept. then your insurance agent then your lawyer . Every one I know of who has had a fire has never been satisfied that they where treated with dignity ,professionally or honestly by the insurance companies . Roy Cooke sr Royshomeinspection.com |
The following is an excerpt from the 1997 Alberta Building Code.
Bedroom windows shall provide unobstructed openings with areas not less then 0.35 sq m (3.77 Sq Ft) and with no dimension less then 380 mm. (15"). If unsprinklered security bars shall be openable from the inside without the use of any tools or special knowledge. Section 9.7.1.3 Alberta building code (1997) Vern Mitchinson CET CMI Past President International Association of Certified Home Inspectors. Alberta
Hi. Roy;
Hope this goes through. http://www.nfpa.org/itemDetail.asp?c...kler%20systems This might help in residential sprinkler systems and yes I agree that any Insurance Company that does not acknowledge the safety and property loss saved by a sprinkler system is taking people over the coals. Marcel </IMG></IMG></IMG> |
dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't know if it's fair to lump ALL Insurance co's together. I've been in the fire & flood restoration buss. over 25 years & have never had a insurance co not want to pay for water or Axe damage caused by the fire dept. Adjustors will pay out according to the type of policy/coverage the home owner has purchased. Just my 2 cents. Doug
So I guess they want you to install one of those multi $$$$ Halon or CO2 systems?
Ya gotta love 'em. Sell you all the insurance you can use as long as there is no risk and no loss! |
do you say if people have a fire the companies do not try and get out of paying for the many things lost in a fire . This is not the case of any I know who have had a fire . Who can remember all the things they have lost . This is where many pictures ( upgraded regularly ) and keep a disk copy at some ones else home . -------------------------------------------------------------------------- I don't know if it's fair to lump ALL Insurance co's together. I've been in the fire & flood restoration buss. over 25 years & have never had a insurance co not want to pay for water or Axe damage caused by the fire dept. Adjustors will pay out according to the type of policy/coverage the home owner has purchased. Just my 2 cents. Doug Roy Cooke sr |
What about legislation the OFM is trying to put in place that will eventually require new homes to have sprinklers? The OAFC is lobbying the government for this at present.
Ron Morrison |
| Tidbits from the ASHI Message Board | jbushart | Misc. Discussion | 124 | 4/27/07 12:05 PM |
| Washington Home Inspections | sstanczyk | Misc. Discussion | 8 | 9/2/06 3:53 AM |
| ILLINOIS Section 1410.200 Standards of Practice | jtedesco1 | Legislation, Licensing & Legal Issues | 11 | 3/9/06 12:22 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues | 0 | 2/14/06 4:38 AM |
