Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 1/9/07, 4:53 PM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
Default Huh?
Abstract
We propose a flexible and efficient wavelet construction for non-uniform B-spline curves and surfaces. The method allows to remove knots in arbitrary order minimizing the displacement of control points when a knot is re-inserted. Geometric detail subtracted from a shape by knot removal is represented by an associated wavelet coefficient replacing one of the control points at a coarser level of detail. From the hierarchy of wavelet coefficients, perfect reconstruction of the original shape is obtained. Both knot removal and insertion have local impact. Wavelet synthesis and analysis are both computed in linear time, based on the lifting scheme for biorthogonal wavelets. The method is perfectly suited for multiresolution surface editing, progressive transmission, and compression of spline curves and surfaces.
Old 1/9/07, 4:55 PM
phinsperger's Avatar
Default Re: Huh?
Old 1/9/07, 6:18 PM
tneyedli1's Avatar
tneyedli1 tneyedli1 is offline
Please Note: tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Huh?
Originally Posted by gluck
Abstract
Design of, construction of, ordering of, placement of, finishing of, removing forms of and admiring of replacement concrete.
"Mayhaps".
T. Neyedli
www.alphahomeinspections.ca
Old 1/10/07, 1:37 AM
gbeaumont's Avatar
Default Re: Huh?
Abstract
I used to suffer from those but drugs and surgery helped
Regards
Gerry
BTW, I know some home inspectors who could have written that
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 1/10/07, 10:27 PM
Default Re: Huh?
From the Canadian income tax return?
