Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 12/9/08, 7:32 PM
Eragorn Northe Eragorn Northe is offline
Default inspecting 83 year old home
this home is on the market but is not occupied,
its winter time (-22) weather.
what or how should I inquire about utilities with realitor?
i would think they might be off, and blocked in, but..
any suggestions, anyone had the same, what did you do?
Eragorn Northe
Der Hous Inspector LLC
cell-306-684-1748
www.derhouseinspections.com
Old 12/9/08, 7:41 PM
Rodney Misener's Avatar
Rodney Misener Rodney Misener is offline
Default Re: inspecting 83 year old home
IMO either they want an inspection or they don't. If so, note all restrictions in report.
Rodney Misener, CMI
Trinity Inspection Services
Pictou County, Nova Scotia
http://www.trinityinspectionservices.com
Certified Master Inspector
Certified Level 1 Thermographer
Certified Energy Advisor
WETT eCertified Inspector
IAC2 Radon/Mold Certified
Infrared Certified
Old 12/9/08, 7:50 PM
I ask my client, when they schedule the inspection, if the utilities are on and operational. I explain that I cannot turn on valve, circuit breakers, light pilots, etc. for insurance reasons and that I do charge for return trips if needed because utilities were not on.
I advise them to verify the utilities are on with their Realtor so that leaves me out of the loop of responsibility on it. This is all, also, in writing.
Then, when I get to the home, I inspect it in the condition that I find it noting things that were not inspected.
Larry Kage, CMI
231 929 3525
Old 12/9/08, 8:03 PM
cool thanks for the replies
Eragorn Northe
cell-306-684-1748
Old 12/10/08, 2:43 AM
Allan G. Berdahl, CMI Allan G. Berdahl, CMI is offline
What Larry said. Further, with no heat(if thats the case when you get there), definately comment on possible frozen piping as you are not sure of the wiinterizing of the home. And if its really too cold to do an inspection without putting your ***** on the line, call the inspection off until a better day(at a cost to the client). Not your fault theres no heat. Good luck with it.
Allan
Allan Berdahl
Aarlan Home Inspection Services
Calgary, Alberta
Bus: 403-808-5355
Cell: 403-803-4064
Fax: 403-204-8863
Email: aarlan@telus.net
Old 12/12/08, 12:23 AM
dcook1's Avatar
dcook1 dcook1 is offline
Please Note: dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ask the realtor before if they are on, mention the limitations it places on you if they cannot be tested. Leaks, hot and cold on right sides, do faucets all work? etc .... you get the point!
Old 12/12/08, 4:26 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Cool Re: inspecting 83 year old home
I did one like that Wednesday.
135 yr old farm house with several additions. Heat was on electrical was working but the plumbing system, well and pump were all winterized.
Forget about having the water on, no one will want to re-activate and then have to winterize it again.
Disclaim the entire system but do a visual - evidence of leaks etc. make sure to mention that to the client before you start.
I have the following verbage for just this situation
"Water supply turned off at time of inspection. The plumbing system could only be inspected visually. Review of the system operation is not possible. Client is advised to review operation of plumbing system prior to close."
Indicate all faucets, drains water heater etc as "not inspected, unable to determine condition."
I do suggest that they get their lawyer to get a commitment to have water on on closing date.
Otherwise just do your thing.
Hope this helps
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 12/12/08, 8:48 PM
it was a chilly inspection, we got her done.
Client phoned realitor and realitor got the water works on for me, in time.
Nasty brown water came out of those taps, yuk.
Boiler system that had not been up dated since house was built, still wrapped in what looks like asbestos, nasty
Eragorn Northe
cell-306-684-1748
Inspector Wendy's Home Inspections-Service Areas wforsyth Miscellaneous Discussion for Inspectors 57 9/5/06 11:10 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
