| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
What's the difference between tread and run in Canada? I'm trying to read up on Alberta's 2006 Code on stairs, and I'm missing the part that defines "tread" and "run." In the US they're the same. Can anyone in Alberta (or Canada) help me? I don't understand.
Thanks. |
Is it true that in Alberta, all interior flight of stairs have at least 3 steps? The way that I read Alberta Building Code 2006 Volume 2, 9.8.3.2, there's a requirement of at least 3 risers in interior flights. You can't have just a step or two?!?
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
By definition a Tread = the horizontal plane of the step (example the step is 10" deep)
Run = is the horizontal distance measured from riser to riser (example 10 treads 10 x 10" (depth noted from example above) = 100" of total run (9'-4") of run Riser = refers to the vertical space or board under a tread Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
I think I get it. So if the minimum run is 210 mm, and the minimum tread depth is 235 mm, as required by the Alberta Building Code 2006 Volume 2.... then the difference between the tread and the run of a stair is the part of the tread that hangs horizontally over the riser below (which is 25 mm max). In the US, that's the nose. I'm I gettin' it?
December 2007 - 10:01 NACHI.TV's Paige Peters gives a ten minute overview of inspecting stairways, covering the handrail, width of the stairway, nose, guards, spheres, handgrips, above and below the stairs, landings, and illumination.
http://www.nachi.tv/episode16 |
Ray,
I think Ben's actually working on making sure that episode complies with Canada laws too. Dominic 2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com |
Raymond,
No sh**t. I produced it (laughing). I'm trying to figure out Canada's Code for Stairs now. (Paige did United States.) Alberta's Code for Stairs is superior to the IRC in many ways. For one... Alberta code of stairs includes the minimal depth, thickness, spacing, etc. for wooden stair stringers. It's all outlined neatly in the Stairway section of the code. Where is that in the IRC? Why doesn't the IRC have that kind of stuff in the stairway section of the code? The more I read Alberta's Building Code, the more I dislike IRC. Last edited by bgromicko; 1/21/08 at 5:54 PM.. |
Oh I see.
I have a concern in National Building Code 9.8.7.2. Continuous Handrail
2) For stairs serving only one dwelling unit, at least one handrail shalll be continuous throughout the length of the sairway except where interrupted d) at changes in direction Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Meaning that the attached pic handrail would be acceptable...
Marcel,
That picture is awesome. And it does not comply with A-9.8.7.2 Continuity of Handrails: "In the case of stairs within dwelling units that incorporate winders, the handrail should be configured so that it will in fact provide guidance and support to the stair user throughout the turn through the winder." A-9.8.4.5 Winders: "The Code permits only 30 and 40 degree angles at winder treads." Those steps seem to have tight angles. And the handrail is not continuous for the lower flight of stairs. |
The National Building Code (NBC) 9.8.7.2 (which is used in Québec) reads: "Continuous Handrail 1) Except as provided in Sentence (2),.. 2) For stairs serving only one dwelling unit, at least one handrail shall be continuous throughout the length of the stairway except where interrupted d) at changes in direction." To me, that handrail is unsafe but is code from where I'm standing unless J'comprends pas! Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Hmmm...
I don't have that written on the doc that I'm reading. I'm reading 9.8.7.2 Alberta Building Code 2006 Volume 2. ", except where interrupted by a) doorways, b) landings, or c) newel posts at changes in direction." Got to have a post. |
For The Record: Provinces in Canada follow the National Building Code (NBC) to which some improved as Alberta did. In Québec we are behind in some area and ahead in others, nevertheless we are Canadian! Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
