Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 5/6/11, 4:03 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Default Leaky windows
Go to http://www.nrc-cnrc.gc.ca/eng/ibp/irc/ctus/ctus-n76.html to see a NRC report on Window Sill Details for Effective Drainage of Water.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
Need a home inspection in Nova Scotia? Check out InterNACHI's listing of Nova Scotia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/6/11, 9:33 PM
Banned
Default Re: Leaky windows
Vern:
In the 2000-2003 period, I believe, CMHC published 4 large ring binders of proven flashing details for various constructions......quite impressive. The above detail is a good one......now to get it in use in the field!!!
Old 5/6/11, 9:54 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Dig a little further and you can find a "bunch" of free publications such as Construction Building Digests, Building Practices Notes, etc.
http://www.nrc-cnrc.gc.ca/eng/ibp/ir...est-index.html
http://www.nrc-cnrc.gc.ca/eng/ibp/irc/bpn/index.html
I have used them as background references for my Building science course for home inspectors.
In addition CMHC has a number of good "Best Practice Guides in Building Technology". The prices vary - some around the $80 - $90 range.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 5/7/11, 9:08 AM
Banned
These were the binders I was referring to in post #2......there may be more of them presently.
http://www.nrc-cnrc.gc.ca/eng/ibp/irc/cbd/digest-index.html
Have a look at the last 2 lines of #9 by Gus Handegord. In Sept/1960, he says vapour barriers should be sealed to make them effective. This is a gent from the "old guard" at Canada's NRC, Division of Building Research that mentored/helped Joe Lstiburek.
I was lucky to have found this free building science series in 1977, my first year working in energy conservation.
Old 5/8/11, 6:26 PM
I subscribed to the "building Digest" from the NRC way back in 1965. Flashing methods that were used worked. For some reason they stopped installing the flashing.
Another problem is the current code calls for the flanged window to be embedded in mastic around the window opening. The builders are not even using the mastic properly and not installing flashing compounds the problem. The code inspectors are not catching it or enforcing the code, hence all the leaky windows. The second source of leaky windows is not a leak but condensation on the cold plastic frame next to the outside because the builders are not sealing the vapour barrier to the inside edge of the window frame. The Alberta government has been studying this problem for over two years as they stated on the "Primetme" TV show that yours truly was on last years summer and still nothing has been done about this problem.
It's costing property owners millions across Canada.
Registar
AlbertaNACHI
Do you like Windows XP rcooke Canadian Inspectors 46 2/2/08 4:54 PM
Free Office Software Eqiv. For Download bmerrell Miscellaneous Discussion for Inspectors 4 12/31/06 11:47 AM
More water, different windows Brenda Exterior Inspections 12 9/22/06 2:55 AM
