Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 9/17/11, 1:33 AM
Roy D. Cooke, Sr's Avatar
Default Mike Holmes' basement renovation tips
http://lifestyle.sympatico.ca/home_reno/basement_renovation.htm?pagenumber=2&paginationena bled=false
by Beverley Ann D'Cruz
Renovation expert and television host Mike Holmes shares his expertise on things to consider when renovating your basement.
You’ve finally decided to take the plunge and renovate the basement into a more liveable space. But before you hire a contractor (or get your own tools ready for a DIY) and start tearing down walls, renovation guru Mike Holmes has one piece of advice, “Slow down,” he says. “I think people go too fast and that has been transformed into renovations, which is a huge mistake.”
So just how should you start preparing for a major investment like this? Mike Holmes has the answers:
Create a wish list
First decide what the space is going to be used for. Whether it will be the children’s play area, the man den or the family entertainment room, everything from the speakers on the walls to the plumbing has to be pre-planned. “Create two things - a ‘needs list’ and a wish list’,” says Holmes. “Stop thinking about how beautiful you want it to look and think about how practical you want it to be. You need to find out everything you can about your area including termites, if there are problems with the plaster and also get it tested for any contaminants, asbestos etc. before the renovation begins.”
Research the products
Basements are known to be damp areas, which inevitably results in the development and spread of mould. “The truth is basements were never meant to be finished,” says Holmes. “It was the utility room that was designed to take the furnace off the first floor of the home. So once you close it all in, it automatically starts to mould and will cause a lot of problems.” To prevent this, Holmes suggests researching products like mould resistant dry wall and BluWood, which is resistant to mould, fire, bugs and water, and will protect the renovation. Ensuring the entire area is insulated properly will also prevent the build-up of moisture that leads to the spread of mould and creates that musty smell.
Hire a contractor
Armed with the knowledge of products that are appropriate for use and the type of space the basement is envisioned to be, hiring a contractor becomes an informed decision. “Now if you know how to talk to your contractor, you can ask him whether he uses things like BluWood or mould resistant dry wall,” says Holmes. “Ask if they are licensed, then ask to see the licence, ask how many basements they have done, how long they have been in the business – these are all important questions. The more questions you ask, the happier you will be and it will be a dream rather than a nightmare renovation.”
Focus on insulation
“Insulation is a really important factor to me,” says Holmes.”The Holmes code would be one inch rigid foam on the floor and two inches rigid foam on the walls. Then on top of the floor foam you need 5/8” tongue and groove plywood screwed through the foam , which will form a thermal break underneath and prevent hot air meeting the cold, so no moisture is created. It will also allow a drainage bed under the foam if there is a flood to get underneath the floor and protect the upper floor.” Similarly, the rigid foam on the walls restricts the air movement behind them that creates condensation and mould.
Keep it eco-friendly
Choosing mould resistant products is the first step to making the basement renovation ‘green’. But that’s not all a renovation can do to make the home more energy efficient. “If you thermo break it i.e. use the above insulations you will reduce the power used by your furnace as well," says Holmes. "The two top places to insulate is your basement properly and the attic. If you do that, you reduce your heating bill by a big chunk every year and that is a big saving that pays you back for years.”
More tips:
- Make sure the area is fire tight since the renovation is taking place near the furnace room. Don’t store any boxes in there.
- Put in a standalone HEPA air filter, which will clear the air on a daily basis instead of your lungs doing the hard work.
- Cutting through the structure of the house is not allowed so keep on top of the contractor and talk to them to make sure that it doesn’t happen.
- Even if no new plumbing is planned, put a camerascope down all the drains to ensure there are no blocks.
- “The biggest mistake is not learning enough for you to personally to talk to contractor," says Holmes. “If you go in blind, you can’t see. But , if you go in with eyes wide open you will understand.”
Need a home inspection in British Columbia? Check out InterNACHI's listing of British Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/19/11, 1:38 PM
Scott May's Avatar
Scott May Scott May is offline
Send a message via Skype™ to smay
Default Re: Mike Holmes' basement renovation tips
Allot of good advice but I dissagree with Mikey on this one line:
Focus on insulation
Please explain to me someone... how there would be much, if any gap between the SM board with 5/8 TG ontop of it and Tapconed to the cement?? It will provide Mikes Thermal Break but no drainage!
That is why I always used Dri Core as the drainage board was attached and there was a difference of 6-8 degrees more warmth. Before that I used a dimple product and 3/4 ply.
I am not saying I am smarter or better or more experienced than Mike but...come on!
He loves to talk!
Try not to become a man of success but rather to become a man of value!
WWW.eyespy-homeinspections.ca
Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton.
Old 9/19/11, 2:03 PM
Wand Raymond Wand Raymond is offline
Please Note: Wand Raymond is a non-member guest and is in no way affiliated with InterNACHI or its members.
I guess he forgot about water vapour coming up out of the basement floor regardless is there is hot air or not.
Old 9/19/11, 2:31 PM
He loves to talk!
I agree with you I used Dri Core and the air is able to go under and keep it from getting damp .
Best thing I have seen to help keep the basement warm and smell free.
Roy
Old 9/19/11, 3:10 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I agree also and do not agree with attaching anything to bridge between the cement wall and inner wall if possible. Putting up Styrofoam SM and gluing it is going to create a moisture block and we know what that leads to. It is true that the water will drain down and not through the SM so this is better than insulation against the wall it just should have a space behind it to allow for venting and a thermal break.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/23/11, 5:58 PM
Leonard Inkster's Avatar
Leonard Inkster Leonard Inkster is offline
Send a message via Skype™ to linkster
“Insulation is a really important factor to me,” says Holmes.”The Holmes code would be one inch rigid foam on the floor and two inches rigid foam on the walls. Then on top of the floor foam you need 5/8” tongue and groove plywood screwed through the foam , which will form a thermal break underneath and prevent hot air meeting the cold"
It will also prevent the heat of the basement permeating the foundation wall in winter and thus lead to a possible lowering of the frost line.
Hasn't Mike ever heard of adfreezing? We get it a lot up here in Canada.
Other than that, love the show, I'd love to go round smashing walls out and tearing ceilings down to really see what's behind them. Oh, wait a minute...I used to.
Future Proof Property Inspections
Leonard Inkster, CHI, IAC2
Proud NACHI Certified Member
Web: http://fppi.ca
Mail: leni@fppi.ca
oovoo: Len Inkster
skype: leninkster
facebook: Len Inkster
You can't depend on your eyes when your imagination is out of focus. (Mark Twain)
Old 9/24/11, 12:26 AM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Nice touch everyone.
I guess Mikey never did home inspections properly or learned how to build adequate insulated basements.
Poor Mike. I guess the attraction of money makes you forget the proper way to build.
As for the insulation on foundation walls.
1.) Sub drain line at footings lowest point.
2.) Aggregate is maintained 3 feet wide to the top of the exterior wall.
3.) All loam is dressed with a good geo fabric
No worries of laterial forces being exerted from deepened frost line.
Have to think out side the box ( our building ).
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Holmes is Back rcooke Canadian Inspectors 0 9/9/11 3:57 AM
'Holmes Inspection' is back rcooke Canadian Inspectors 4 9/8/11 8:24 AM
Mike Holmes on CBC MarketPlace rwand1 Canadian Inspectors 31 1/11/07 6:12 PM
