| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
Has anyone done alot of mobile home inspections ? is there any courses on them , anything will be appreciated, any special reporting books, etc.
thanks Joe |
| Need a home inspection in Newfoundland and Labrador? Check out InterNACHI's listing of Newfoundland and Labrador certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
When in the crawl area watch out for electrical wiring and wild vermin.
Look closely for re-done poly plumbing and vapor retarders installed on the warm side in the crawlspace. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
See 24 CFR 3280.
This is another link for what Jim posted;
http://www.access.gpo.gov/nara/cfr/w...fr3280_99.html You might want to check here also for some help. http://inspectapedia.com/structure/m...nspections.htm Also check you Jurisdiction for tie-down requirements. http://www.nachi.org/manufactured-home-tie-downs.htm LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Depends where you are inspecting. Assuming this being asked in the Canadian section perhaps consider the points offered by another Canadian inspector such as http://www.allaroundthehouse.com/lib.mno.na57.htm
Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
I apologize Claude, I failed to notice this was in the Canadian thread, but upon reviewing the contents of your link, I do not see where inspecting a trailer in Canada is any different than here in the US.
I respond to anyone in Inachi that needs assistance, if I can help. The poster asked a question and no listing of the geographic area was listed. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel not a problem, I did not take it as an issue. I agree, however, newer codes - where applicable may be slightly different across Canada.
I also agree, a lot of common concerns from a saftey and habitability POV are shared regardless of the borders. Cheers, Claude Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| California Home Inspections | whandley | Miscellaneous Discussion for Inspectors | 17 | 6/4/08 12:28 AM |
