Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/14/08, 6:20 PM
lolsen lolsen is offline
Question Moisture around attic hatch
I have ran into this a couple of times. Moisture stains around the attic hatch. One on a 8 year old house and another a 3 year old house. Why??? The bathrooms vent outside and the attic appears to be vented enough. Any Ideas?
Thanks
Lawrence
Old 3/14/08, 6:34 PM
ldapkus ldapkus is offline
Default Re: Moisture around attic hatch
Could be they have the humidifier cranked up. Indoor RH should be 30%-50%. I have had many calls this winter because of this. First thing I do is pull out my hygrometer and check humidity. Usually it's too high. Was there mold in the attic???
Old 3/14/08, 6:38 PM
David P. Valley's Avatar
Thanks
Lawrence
Attachment 19578
What was the moisture content at the stained area?
Old 3/14/08, 7:01 PM
No mold in the attic.
Moisture content around 15% but a couple of inches from the stain there was nothing.
Thanks
Lawrence
Old 3/14/08, 7:05 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
by looking at that pic, it does not look like moisture to me. If you look at the right corner of the panel it is raised up a bit. that yellowish brown streak is probably dried up oozy glue from the strip they put in there to prevent cold air from coming out of the attic and into the house. I see this alot, most of the time the hatch is stuck shut because of this stuff. then you have to bang on it to get in. Might be wrong but that's my guess, can't zoom in far enough to be positive.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 3/14/08, 7:20 PM
Not glue. Moisture test confirmed.
The seal is not on the hatch it is on the ceiling.
Here is a picture of the hatch in the attic.
Lawrence
Old 3/14/08, 7:54 PM
Attachment 19581
Lawrence
Hi Lawrence
In my area the hatches are not normally stippled. The stippling could be preventing the weatherstripping from providing a good seal. Moisture in the household air could condense around the edge of the hatch and leave that water mark.
Old 3/14/08, 7:56 PM
iniquette's Avatar
Attachment 19581
Lawrence
Well, with that pic, then I would agree with John's guess. Sounds conceivable.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 3/14/08, 8:10 PM
Thanks
Lawrence
If you've got 15% moisture content on wood, IMO..that is not a big deal.
Old 3/14/08, 8:22 PM
David
Might not be much but the home owners were concerned. 3 year old house that has been a nightmare.
They answered yes to my sign at the trade show on the weekend. More pics to follow.
Thanks
Old 3/14/08, 9:22 PM
jkogel jkogel is offline
David
Thanks
Lawrence Attachment 19585
You are right, Lawrence, there appears to be warm moist air leaking up into the attic and that is never a good thing. That yellow tar could be from smoking, BTW. They may need ventilation improvements, the rest of the house is tooo tight!
Old 3/14/08, 9:45 PM
Banned
No, they need to stop smoking!!
With the price of energy rising like it is, no house is ever too tight. Just need to know how and when to ventilate the interior spaces.
Old 3/14/08, 9:57 PM
Not Smoke.
The house is anything but air tight. Did a thermal scan and found endless air leaks, and missing insulation.
Lawrence
Old 3/14/08, 10:05 PM
David A. Andersen's Avatar
Looks like we need to learn some psychrometrics.
Yes, it is beyond Home Inspection, but when you start with the IR stuff you need to know it.
Did you obtain any psychrometric measurements of the indoor air I can work with?
Old 3/14/08, 10:20 PM
Banned
Here's a start!!
Dry Bulb- 74 deg
Wet Bulb-60 deg
Truss Uplift rcooke Canadian Inspectors 5 2/26/08 8:43 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
