Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/10/10, 12:33 PM
Patrick Massie's Avatar
Patrick Massie Patrick Massie is offline
Default My first inspection
Hi Guys!
Last week i called my uncle and asked him if i could inspect his house (for free of course) he said yes.... in a nervous way...
Altough he had the house inspected 4 years ago (everything was fine according to the HI) i was certain that i could find something and i did.
I noticed a lot of problem not listed in the report..but the biggest one was this one:
in is bedroom, one wall had a visible damage , the drywall was all ''puffed up'' (moisture meter read 10%...but a huge baseboard heater was under the damage area...so i didn't take the 10% moisture content too seriously) , i asked my uncle how long it was like that and he said : since the first i bought it from my dad.. and he added the the inspector said that the window was leaking , (4 other contractors said the same thing)..
the window that i just inspected was perfect (and had never been chaged) the roof did not leak it was 4 years old...and the attic, including insulation was dry...
so where the hell did this come from?????
i went back out side and i was determine to get to the bottom of this
i looked and looked for the answer.. and i found it
The siding of the house is brick , on the first row i noticed that no weep holes where visible....anywhere ....turns out that my grand father filled them up (all of them) with concret (i noticed small color chages in the mortar , between the bricks)
this rework has been done at least 20 years ago...so for 20 years the water and humidity had nowhere to go ....
i will opened up the walls this week end and see the damage
i will post the report here so you can see other stuff i found...and judge my first report
uncle is not happy....................
my-first-inspection-2010_03062010neige0042.jpg   my-first-inspection-2010_03062010neige0035.jpg
Need a home inspection in Nova Scotia? Check out InterNACHI's listing of Nova Scotia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/10/10, 12:36 PM
Bob Elliott's Avatar
Default Re: My first inspection
Good job.
Your Uncle may hate you for a while. $$$$
Old 3/10/10, 12:38 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Good one. In my initial inspection training class I took several years ago a student told us he spent the whole weekend filling the little tubes (weep holes) with concrete on his newly built home. We all had a good laugh at his expense.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 3/10/10, 3:54 PM
Chuck Evans's Avatar
Since you didn't charge for the inspection, now you can bill him for the repairs.
Suggestion: Never do a free inspection when just getting started, even for friends and family. Charge $1 and count it as a paid inspection.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 3/10/10, 4:02 PM
Jeffrey R. Jonas's Avatar
Chuck,
This may have been one of his 4 mock inspections for INachi, which needs to be completed before he may charge a fee for an inspection.
But, yes, a good point to remember. (Wish I thought of that years ago)
Old 3/10/10, 5:20 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
good job
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 3/10/10, 8:26 PM
question : where do i submit my 4 inspections?? directly to Nick??
Old 3/10/10, 8:40 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Go into your members log in, up in the right hand corner. There is a spot in there to submit your reports for verification.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 3/10/10, 9:10 PM
Banned
Hi Guys!
i will post the report here so you can see other stuff i found...and judge my first report.
Most likely the weep hole blockage has nothing to do with the water damage under the windows......there is leakage at the window somewhere. It may look fine with no visible defects....... until......some wind-driven horizontal rain hits it .....or the trim ....or some other element above the window!!!!!
Old 3/11/10, 1:53 AM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
Well around here if the blinds and curtans are closed you will get a lot of moisture (WATER) on the window and it will leak inside of the wall from inside of the home. Just a thought.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 3/11/10, 2:01 AM
hlowe's Avatar
hlowe hlowe is offline
I agree with Charles. It's quite common to find this kind of damage, under those conditions. Old folks tend to use the drapes as insulation, not realizing the sometimes excessive amounts of condensation that are formed on the glass. If there is anywhere the water can find a way into the wall through the sill; it will do so, causing rot, and probably heavy mould.
Harold J. Lowe C.M.I., C.C.I.
Eagle-Eye Healthy Home Inspections
Sharondale Academy of Home Inspections
www.healthyinspections.com
harold@cannachi.org
haroldjlowe@hotmail.com
home-905-576-4337
cell-416-912-0852
CanNachi Director of Education
Pro-lab Certified Mould Specialist
IAC2 Certified Indoor Air-quality Consultant
Certified Commercial Inspector
Toronto/Durham/Kawarthas
Proud InterNachi Member # 06091197
Old 3/11/10, 9:26 AM
iniquette's Avatar
I agree with Charles and Harold. Have seen that a lot with a longer curtain. The window condensates and the curtain doesn't allow it to dry out properly and you end up with a big mess. Don't get me wrong, this may not be the only answer, but it is a possibility.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 3/11/10, 10:30 AM
Marcel Gratton's Avatar
Patrick,
From your pick, I would say that wall damage comes from the window leaking.
And I would check the rim joists and sill plate in basement for possible rot due to the blocked weepholes.
On The Level Inspection
Gatineau, Québec
Old 3/11/10, 11:27 AM
Originally Posted by mgratton View Post
Patrick,
Hi Marcel, hows life treating you, long time no chat. Hope all is well with you and yours. Chuck.
