Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 11/15/06, 8:42 AM
George Mendes's Avatar
George Mendes George Mendes is offline
Default Oil Tanks - how often do they get inspected?
Does anyone know if there is a mandate for oil tanks to be inspected annually in Ontario. I was asked this yesturday while doing an inspection. Also, would any of you recommend any good websites regarding further information on Oil Tanks and there use in Ontario.
Cheers,
Old 11/15/06, 8:56 AM
Joseph D. Skrypka's Avatar
Joseph D. Skrypka Joseph D. Skrypka is offline
Default Re: Oil Tanks - how often do they get inspected?
All tanks are required to have annual maintenance, performed by a TSSA certified oil burner technician. This includes visually inspecting for leaks and testing and servicing the unit to ensure that it is operating proberly. It is the owner's responsibility to arrange / ensure they have yearly maintenance examinations.
In addition, a comprehensive inspection by the Fuel Oil distributor is required at least once every 10 years. This is performed to ascertain compliance with the regulations and code.
For more detailed information check out the TSSA site. Here is the link for FAQ's regarding fuel oil: http://www.tssa.org/regulated/fuels/
Joe Skrypka MBA RHI CMI
The Home Inspection Guy Inc.
Hamilton, Ontario Canada
Membership No. NACHI050062193
Old 11/15/06, 9:10 AM
Roy D. Cooke, Sr's Avatar
Originally Posted by jskrypka
All tanks are required to have annual maintenance, performed by a TSSA certified oil burner technician. This includes visually inspecting for leaks and testing and servicing the unit to ensure that it is operating properly. It is the owner's responsibility to arrange / ensure they have yearly maintenance examinations.
Also Some insurance companies will not give insurance to tanks older then 20 years most are 25 years . I do not believe TSSA has set life but most oil suppliers ,( they do the inspection ) recommend they be changed at 25 years . you can still have a buried Oil tank but they need to be inspected more often . .If A person has a buried older tank let them know some insurance companies will not give insurance ,period. The tank can only be removed by a qualified contractor and this can be expensive depending on amount of oil in tank and tank place and condition
Roy Cooke
Old 11/15/06, 9:29 AM
Roy:
You're right, notwithstanding the fact that above ground oil tanks can be kept indefinitely as long as they are not leaking (per TSSA) see http://www.tssa.org/public/consumer/...me05.asp#ast01 it is often the insurance companies that dictate when a tank must be removed.
Regarding in-ground fuel oil tanks, there is a regulated time-line published by TSSA advising how long these tanks can stay in the ground before having to be removed. For example, tanks that are older than 25 years (or if the age is unknown) had to be removed by October, 2006. Here's a link that gives more information:
http://www.tssa.org/public/consumer/...umerHome04.asp
Old 11/15/06, 9:43 AM
rwand1 rwand1 is offline
All inspected interior and exterior above ground tanks will have a green plastic card indicating when last inspected. The tag is attached to the filler or breather pipe on the tanks.
Old 11/15/06, 9:44 AM
Roy:
Thanks for the upgrade Joe . I was going from memory .
As I do my report on site I try to be correct .
Another oil tank concern easy to miss is I believe all tanks must be more then then ten feet from the property line .
This can be awkward in some close cottages in many areas.
Roy Cooke
Old 11/15/06, 10:14 AM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Keep in mind that the oil line from tank to furnace must be installed above the basement floor slab. they used to be notched into the slab and covered with cement but this is no longer allowed.
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 11/15/06, 10:33 AM
Doug - I believe that the above-slab oil line also has to be protected from damage by some kind of a covering - usually hard plastic. I'm not sure on this - maybe someone else can confirm.
Old 11/15/06, 11:08 AM
Yes copper lines must be orange plastic sleeve, and I believe bare copper is permissable below cemment if run in plastic tubing. Copper and cement in contact with one another result in the copper failing over time.
Old 11/15/06, 12:48 PM
Joseph:
That's true. Can't be bare copper, has to have plastic coating, usually orange or red.
Cheers
Services Inc.
Whitby Ontario
05021384
Old 11/17/06, 1:44 PM
chuckb70 chuckb70 is offline
Please Note: chuckb70 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a question, my own house has the oil line running across the basement ceiling and never touches cement. It drops down beside the furnace and the filter is just outside the furnace. Bare copper all the way. Would this be classed satisfactory when doing an inspection? I would think so. Chuck
Old 11/17/06, 4:42 PM
As long as its not in contact with cement or damage it would be okay.
Any good checklist for HVAC cgoyette Inspecting HVAC Systems 3 8/1/07 3:32 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
ILLINOIS Section 1410.200 Standards of Practice jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 11 3/9/06 11:22 AM
